Dash Question!!!!
you there is 2 screws in the side of the wheel that you have to take off. then the center piece will come off then you have to get a wheel puller to get it off. then there is a piece that has the winsheild wiper controls and your turn signals switches there is one screw behind it in the middle that you just losen then it just slides off too.
there is 2 screws one the wheel itself. there is one each side of the wheel. after you get them you can take out the the airbad in your wheel. then you have to unplug the airbag and then take out the bolt in the middle that is holding your wheel. you will need a wheel puller though if you dont have one then you better get one or have someone let you use theres cause it wont come out without.
if you got the wheel off then there all the way off there is a plactic peice that will slide right off then there is another peice that has you you turn signs and your wipers. there is one screw that is holding it down. if you look from the top its right there in between the 2 switchs and rigt in the middle of the steering column. unscrew it and it should slide right off, then all you have to do is just pull out the dash and slide the switch through that opening.
yeah I have that off (I broke it in the process
) I'll look for that screw at the top when I go over to my car tomorrow. If I can't get it then I'll take some pics.....thanks for the help guys......awesome!
) I'll look for that screw at the top when I go over to my car tomorrow. If I can't get it then I'll take some pics.....thanks for the help guys......awesome! Thread
mjdiaz89
Jun 21, 2016 09:26 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
NoobyKid
Jul 13, 2015 07:53 AM
