Dash Question!!!!
Old Feb 6, 2005
BIG's Avatar
BIG
Dash Question!!!!
How do I get my dashboard around my steering column and turn signal arm etc??
Does the dash come apart in more then one piece.....HELP!!!
Old Feb 6, 2005
BIG's Avatar
BIG
someone must know!!!
Old Feb 6, 2005
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
need pics, but it should fit around everything, just take your time and you will get it our dashes are some of the easiest i've ever done.
Old Feb 6, 2005
BIG's Avatar
BIG
I've tried everything I can't get it around the column....has anyone done this yet?
Old Feb 6, 2005
buck's Avatar
buck is an unknown quantity at this point
you there is 2 screws in the side of the wheel that you have to take off. then the center piece will come off then you have to get a wheel puller to get it off. then there is a piece that has the winsheild wiper controls and your turn signals switches there is one screw behind it in the middle that you just losen then it just slides off too.
Old Feb 7, 2005
BIG's Avatar
BIG
serious?! is it on top or underneath somewhere (my car is in a garage, so I can't see it till tomorrrow )
Old Feb 7, 2005
mradam85's Avatar
oh yeah thats right i think the screws are on the underside
Old Feb 7, 2005
buck's Avatar
there is 2 screws one the wheel itself. there is one each side of the wheel. after you get them you can take out the the airbad in your wheel. then you have to unplug the airbag and then take out the bolt in the middle that is holding your wheel. you will need a wheel puller though if you dont have one then you better get one or have someone let you use theres cause it wont come out without.
Old Feb 8, 2005
BIG's Avatar
BIG
I've got everything off, but I still can't get the dashboard over the turnsignal and wiper arms......I need HELP!
Old Feb 8, 2005
chicohonda02's Avatar
Since 2002 Baby!
pics would help a whole bunch. i'm a visual type. must see first.
Old Feb 8, 2005
BIG's Avatar
BIG
ok, I'll try and take some pics of it tomorrow
Old Feb 8, 2005
buck's Avatar
if you got the wheel off then there all the way off there is a plactic peice that will slide right off then there is another peice that has you you turn signs and your wipers. there is one screw that is holding it down. if you look from the top its right there in between the 2 switchs and rigt in the middle of the steering column. unscrew it and it should slide right off, then all you have to do is just pull out the dash and slide the switch through that opening.
Old Feb 8, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Screw #21 and #23 in the pic.
File Type: jpg
Old Feb 9, 2005
buck's Avatar
yea i fotgot to tell you that you need to take off that skirt first
Old Feb 9, 2005
BIG's Avatar
BIG
yeah I have that off (I broke it in the process ) I'll look for that screw at the top when I go over to my car tomorrow. If I can't get it then I'll take some pics.....thanks for the help guys......awesome!
GotSiR
Jun 23, 2016 04:06 PM
mjdiaz89
Jun 21, 2016 09:26 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
