04 suspensin same as 01-03?
Old Jan 7, 2005
MegaHurtz's Avatar
If I wanted springs that fit an 01-03 or other suspension componets for the same years, will they fit my 04?
Old Jan 7, 2005
takumi's Avatar
takumi is on a distinguished road
Springs will fit, but you need 03-05 shocks.
Old Jan 7, 2005
standalj's Avatar
standalj should not be trustedstandalj should not be trustedstandalj should not be trusted
Not all suspension components from 2003-prior will fit our 2004. As a matter of fact, a lot of other parts from 2003-prior will not fit our 2004. Make sure you validate with the manufacturer whether the parts are compatible enough. Of course, with enough fabrication you can make most anything fit.
Old Jan 7, 2005
MegaHurtz's Avatar
I am talking about just springs in my case... thats all I am looking to install
Old Jan 8, 2005
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
Well now aren't the tables turned? Damn suspension newb.. j/k! Yes springs from 01-03 will fit 04-05.... There are minor suspension differences among the years but i don't believe the springs are one of them.
Old Jan 8, 2005
standalj's Avatar
I believe you are good to go in terms of using springs from an 01-03.
Old Jan 8, 2005
robbclark1's Avatar
Retired suspension supermod.
springs will fit, some shocks need to be modified or made sure the shock body is the right mm width.
AyyeeGeorgee
Sep 14, 2015 12:54 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
jimmyfloyd
May 20, 2015 07:06 PM
01Driver
Jan 18, 2004 10:47 PM
Kairi
Aug 2, 2002 01:37 PM
