MAx Hp with Bolt ons (2005 SiG Coupe)
Old Dec 30, 2004
lowther420's Avatar
lowther420 is an unknown quantity at this point
I know i can put a turbo in it - but i just bought it and where i live there is no specialty car shops around to do proper tuning etc
And i really dont want to go messing around with the engine too much (waranty etc)
Also i am not looking to race my car i just want to add a little more power ( I know i should have bought a car with more horse blah blah blah - I bought the car cause i love the look)
is it possible to gain another 50 hp at least with bolt ons - cause thats all the horse ill ever need lolol.
And if so do u have any siggestions as to what i wll have to purchase
and whats the best route to go,
Thanks in advance
Dave Lowther
Old Dec 30, 2004
SLO REX's Avatar
250+ awhp Stage 2
Nitrious, would get you that 50 hp you want...I think you can also run a 50 shot on stock everything...or just maybe #7 ngks and some premium fuel...
Old Dec 30, 2004
AzNmiKex215's Avatar
2k1civic.com O. G.
50 additional wheel horse power on a D17 motor with every normal bolt on, pulleys, cam gear, exhuast, intake, header, is IMPOSSIBLE.
The only "bolt" on that i can see giving massive gains is individual throttle bodies. but taht requires some pretty heavy tuning and things like cams etc.
The max WHP i think anyone can get with I/H/E on a 7thgen civic is somwehere near 110 - 120 IF your lucky.
Old Dec 30, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
50HP from bolt ons? Maybe on a Toyota Supra......
dont quote me on this, but with typical bolt ons... maybe 8-10.....
Old Dec 30, 2004
Tipsy_AA's Avatar
Tipsy_AA has a little shameless behaviour in the past
once you bolt ur first bolt on....ur warranty for YOUR ENGINE is gone...if your worried about ur warranty...go work for stuff like your suspension, interior, exterior and when ur warranty is up.. then go work on your engine....thats the way im goin...you can always start off with I/H/E/(intake,Headers, exhaust)...for your first bolt on.
Old Dec 30, 2004
jakejham's Avatar
jakejham should not be trustedjakejham should not be trusted
just stay stock. better low end torque and saves money. if you need cool sound get the injen sri and HKS hi power axle back (for angled look)
Old Dec 30, 2004
SLO REX's Avatar
250+ awhp Stage 2
If they can prove the bolt-on is the cause of the problem, then that can void your warranty...I talked to a guy at the Honda Dealership...He said, "If the performance part is not the cause, then there is nothing that can be done to void your warranty" I blew my motor 2 times before 8,000 miles, and on one of them I blew a spark plug thru my hood...I had exhaust, headers, and CAI and they fixed my car both times...My car misfired at around 700 rpms while I was at a stop light. That is right 700 rpms
Old Dec 30, 2004
once you bolt ur first bolt on....ur warranty for YOUR ENGINE is gone...if your worried about ur warranty...go work for stuff like your suspension, interior, exterior and when ur warranty is up...
what makes you think that doing suspension mods doesnt void warranty as well?
Old Dec 31, 2004
nickm748's Avatar
Some dealers can be dicks though and just cancle it if it is proven to be the problem or not
Old Dec 31, 2004
hotrodcivic2004's Avatar
my civic has no boost
then they are breaking the law because it has to be proven. if they cant prove that the little sri is the cause of one of your valves melted into your piston from high reving valve float then they have to fix it. but if they discover that they are aftermarket valves that are not strong enough to handle the higher rpms or different valve springs then the warranty has been voided.
Old Dec 31, 2004
exclusive_vtec's Avatar
keep ur car stock...
Old Dec 31, 2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
Originally Posted by AzNmiKex215
50 additional wheel horse power on a D17 motor with every normal bolt on, Cams, exhuast, intake, header, is impossible.
there was a dyno posted some time ago with I/H/E and a lightened flywheel that was a bit over 125whp. I think that the flywheel makes the greatest difference, atleast that is what I felt when I added the lightened flywheel.
Old Dec 31, 2004
2k1civic.com O. G.
Isnt there negatives to having a lighter flywheel? The one i know is that the car tends to stall in low RPM's or something like that.
Old Dec 31, 2004
some lighter flywheels have a constant clunking noise at idle.
Old Dec 31, 2004
civic01vtec's Avatar
lol..........flywheels don't give you extra hp......it just frees up what is there.
Old Jan 1, 2005
usafstud's Avatar
I got 119.1 WHP on dyno
dyno was done by HONDATA
i have custom made intake and custom made test pipe
10.7 lbs 15' wheels on kumho MX
i'll try to scan the sheet when i have a chance at work
Old Jan 2, 2005
nindoo's Avatar
Why is my vagina bleeding?
I ve seen a post of someone with a lightened flywheel and aftermarket clutch with 120 something wheel HP, who knows though the dyno could have been rigged.
Old Jan 2, 2005
allmotor's Avatar
nor cal 7thgens
i/h/e 50 shot
Old Jan 2, 2005
bgoetz's Avatar
were did I say that the flywheel "gives" extra hp. And besides if it is freeing up hp it is increasing the hp. Hence a faster feeling higher dyno car. This is a great example of a compleatly pointless flame attempt
Old Jan 2, 2005
no, not a attemp to flame. If i would, i would have went y0u suck at teh intran3t and u ar3 a c0mplet3 dumb4ass, s3aRch u n00b
anyway, a lighter flywheel allows the crank to spin fast which in turn allows you to accelerate faster. Doesn't give you more hp, just gets you there faster That is why you feel the increase in performance.
Old Jan 3, 2005
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
dynoed 125 whp and 113 trq with boltons
Old Jan 3, 2005
Addicted To Boost
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Dorval Andre
May 1, 2015 09:37 AM
Dorval Andre
Apr 20, 2015 05:34 PM
robbclark1
Dec 12, 2001 12:18 PM
SneakerPimp
Dec 7, 2001 07:09 PM
