new key problems
new key problems
I had a new key made for my civic and it wont start the car all the way... i kno our cars come with the immobilizer system...so is there a way that i can set it up to recognize my new key
the dealer told me the key acts as an antenna and is really just sending the signal from the chip (his metaphor or whatever for explaining it)
he also said copies will only work for doors/trunk etc, and WILL NOT start it, and to get a copy u HAVE to goto the dealer.
i make keys at work and the one i made for the car doesnt turn it on. the one i made only opens the doors and trunk but when its in the ignition it cranks it but doesnt start the car. in fact, all newer cars that are out i cant make a key for them cuz of the chip in side.
you'll have to go to honda and get it done
Any locksmith with a handheld programmer can make a key for your car. It's a matter of whether or not the locksmith has the programmer which determines if he can program a key to the car. There are aftermarket transponder keys available for almost every car on the market. They generally cost a lot less than the dealer. ILCO makes an aftermarket key for Hondas. I should add that there are 2 ways to get a new key to work with your vehicle. 1) Use a handheld programmer to program in the new key to work with your ecu. 2) Clone an existing transponder to the new key with a key programmer. The second option isn't wise if you lost a key. You want to use option 1 to erase the lost key so it can't be used to start your car by an unauthorized person. Also, not all transponders can be cloned.
So, um, what happened to your second set of keys?
It won't recognize your new key, unless like mentioned you some how get it to produce the same thing a stock one does...
Originally Posted by AggressiveAdam
im highly doubting your going to find any key smith with a programmer. Besides honda
Depends on where you live I guess. In Vancouver, BC there are mobile locksmiths who can make and program a key on the spot and program your ecu. They can also clone a key if you bring one into their shop.
Im off to vancouver in feburary for powder season @ whistler
Originally Posted by againifall
yeah.. the big AAA subcontracted companies around here also can program a key on the spot..
CarStuff
Dec 6, 2020 12:52 PM
PinkCupcakes
Electronics
Jul 18, 2019 12:50 PM
beveragemp
May 25, 2015 07:11 PM
