Trunk Bounce?!
Old Dec 19, 2004
Cubbies60's Avatar
Cubbies60 is an unknown quantity at this point
Trunk Bounce?!
I have a 2004 EX Sedan. When I open the trunk with the inside lever, the trunk won't close right the first time. It "bounces" once then I can shut it. When I open the trunk with the key outside, it catches the first time. What do you think is wrong?
Old Dec 19, 2004
You're not closing it hard enough. It's better to have it tight to keep noise out, but if you want there are rubber stoppers that you can tighten so the lid closes easier.
Old Dec 21, 2004
2K1Civic17"Gabe's Avatar
I have the same problem on my car. Sometimes takes like 10 times to shut. What you have to do, is raise the latch that the trunk closes onto (the latch above your bumper). I use the backside of a hammer and pull a little bit. BE CAREFUL OF PAINT! If you pull up to high and have a system, you will get air coming out, and youll have to hammer it down a tad bit untill you are happy. It should last a few months, than do the same thing if it goes back down. Takes you 1 min to do. You can buy a new latch, but I figured this is free and much quicker/easier.
Good Luck! try it out, it will work!
Crazygrlinak
Oct 8, 2015 05:06 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
Skunkone
Sep 24, 2015 04:38 PM
MamaBear2015
Sep 15, 2015 09:35 PM
