Is there a problem with my car??
Old Dec 13, 2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
Ok sometime back I missshifted from 5th to 2nd on accident. Now despite what most people think the car does not instantlly spike to 9k. Due to the fact that that type of shift causes the clutch to slip like hell. However my car did hit around 8k. Everthing seemed fine but I ran a compression test to be sure my #s were 180 165 180 180. According to the helms this is good. Well recently it has not felt like the Vtec has been working (which would make sense if I bent intake valves). So I took the compression again my #s were 180 180 165 180. WTF??? I personally think despite the fact that the helms says no less than 130 with a variance of 28 a new car should have no varience at all.
Old Dec 13, 2004
turboengnr's Avatar
DONT PANIC
all cars can have variances in them. My vette motor is all new. New sleeves, new rings, new pistons, etc. After doing the pre-lube and turning it over a few times, my compression was 245, 243, 220, 234. The compression depends on numerous variables.
If you dont believe me, try this.....
Take out your spark plug and port about 2 oz of oil down there. Then immediately run a compression test. You will notice that the compression is much higher.
Old Dec 13, 2004
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
If you bent a intake valve the compression would be really messed up.
Old Dec 14, 2004
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
i did the mis shift and my rpm's hit over 9k. just to let you know.
Old Dec 14, 2004
tacheon's Avatar
tacheon is on a distinguished road
Aren't you the pinhead who drove drunk? Didn't get a very good response from the previous post I see.
http://www.7thgencivic.com/forums/sh...d.php?t=187257
You don't deserve any help on this at all.
Old Dec 14, 2004
bgoetz's Avatar
I drove down my freaking drive way that is about 1/2 mile long drunk. MY DRIVE WAY endangering only my self. The topic got closed for a reason because it got off topic. And if dumb A$$es such as yourself post **** like that in a compleatly legit topic were someone is simplly looking for advice. This topic will to be closed. Thanks in advance for rendering my topic useless
to the rest of you I am getting some good advice so please don't follow in this idiots footsteps or I will have the topic closed
Old Dec 14, 2004
bgoetz's Avatar
it will if you don't push the clutch in fast enough.
Old Dec 14, 2004
PunkingCivic's Avatar
I need TP for my bunghole
if you are worried got have the ecu hook up and see if you have codes spitting out.
Or buy an ODB II code reader.
It plug in to the top right of the gas pedal
The socket is grey
www.harborfreight.com has one for $40
http://www.harborfreight.com/cpi/cta...emnumber=46030
Old Dec 14, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
he last time my compressin check said 180 165 180 180, my hg was blown
Old Dec 14, 2004
bgoetz's Avatar
that makes me feel good. Maybe I have an exhaust or header leak I did use all of the old gaskets. What gets me is that it switched from cyl 2 the 1st time to cyl 3 the second. Any ideas??
Old Dec 27, 2004
ty.barrack's Avatar
ty.barrack is an unknown quantity at this point
its only 15 off on one piston, but that doesn't sound good, if all the other three are at 180 exactly, I would take the head off, and have a look.
Xuhme
21
Aug 7, 2023 03:40 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
tylerginevan
Apr 27, 2015 12:29 PM
McD
Apr 16, 2015 10:46 AM
dooner24
Apr 14, 2015 07:51 PM
