Problem With OEM Sway Bar End Links, Help!!!
Last night I was removing my aftermarket exhaust which was welded on and after removing all the hangers, I then realized it was welded on and I tried pulling it through the back, but the sway bar was in the way, so I decided I would remove it. Well I started to remove the bolt on one side of the end link on the top, but it didnt come all the way off, it just kept spinning. Well after trying to tighten it back up, I still had the problem of the bolt spinning. So now I have a loose endlink because the top nut wont turn. When I try to tighten it, the hole bolt spins. There is a circle washer in the middle, do I need to hold that while I turn the bolt? I tryed doing that last night but nothing worked. What do you all suggest I do here? I know some of you have experience with the endlinks. I dont want to drive the car yet because of the loose endlink.
Yes, it's an Acura EL
So did you use a 5mm Allen wrench in the slot right in the middle of the endlink nut? You have to hold a 5mm wrench in there while using a 14mm wrench to loosen/tighten the actual nut. Otherwise it'll just keep on spinning.
Haven't read the DIY on endlinks by Grey? Listen to Telly, he is a smart dude, even if he owns an acura Thread
Dorval Andre
May 1, 2015 09:37 AM
zcwagon
Apr 24, 2015 05:18 PM
jessepimpride
Nov 13, 2001 05:59 PM
