Ive Decided on Suspension, but have questions
Old Dec 11, 2004
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
So ive decided that in the near future i will be buying neuspeed race springs, kyb agx's and an spc camber kit for my 05 LX Coupe...from TrueHonda...
is there anything i should know? in particular any mods needed to these to fit? or should they work directly
thanks...
oh and id like to get your input on the setup
Adam
Old Dec 11, 2004
robbclark1's Avatar
Retired suspension supermod.
You might need to bore out the mount bolts on the front KYBs to 16mm and remember to get the 03+ front camber kit. Other than that, just take the mount off the stock shock/spring and put it on the new set up. Read the Spring/DIY. It has a lot of good info and pics. Setup is fine. It seems like I repeat myself over and over again, but opinions aren't going to do ****. Both neuspeed and KYB make good stuff and I commend you on picking quality products!! But people are gonna say get this or get that. Do what is best for you and what you want to do with the car.
Old Dec 11, 2004
i do have the money to get teins, but by saving a little and not sacraficing that much quality, i can get the dezod turbo kit faster...
thanks for the info on the kyb's...
Old Dec 11, 2004
robbclark1's Avatar
Your front mount bolts are 16mm and they kyb's should be made for the 01-02 with 14mm bolts. Ask your supplier if kyb makes them with 16mm holes, if not you will just hvae to bore the 14mm holes to 16mm.
Old Dec 12, 2004
TrueHonda? Got an answer? LOL
so your saying if i get the 01-02...i have to modify/widen? the holes at the top of the suspension?
Old Dec 12, 2004
flotsamm's Avatar
No, the two holes at the bottom of the strut where the steering knuckle is installed will have to be widened. However, I thought that the AGX's can be purchased either way. Not sure though, best to call.
Old Dec 12, 2004
robbclark1's Avatar
No, the steering knuckle is different. That is the tie rod bolt, and that should be the same.
You need to widen the MOUNT holes. The bolts that hold the strut to the brake hub. I would call KYB to ask if they make different ones.
Please read this
Old Dec 12, 2004
is it that hard to modify if kyb were not able to accomadate me? cause i do have my friend that works at a speed shop to my install...so he should be able to do it if he needs to rite?
Old Dec 12, 2004
flotsamm's Avatar
Rob, the steering knuckle and brake hub as you call it are the same thing. Its the lower part that connects to the strut housing that has two bolts and nuts.
Old Dec 12, 2004
robbclark1's Avatar
eh...just terms.... learn something new everyday...Guess I am not as smart as I wish I was
Old Dec 12, 2004
so even if kyb cant send me the right ones, im assuming people on their own have done this modification and should be cake for a performance mechanic no?
Old Dec 12, 2004
robbclark1's Avatar
Yes...search for specifics. They are on the site in this forum especially with tokicos.
Old Dec 12, 2004
icic...well im sure its not that hard to do...but thanks for the info
Old Dec 13, 2004
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
You know where to find us when your ready
Old Dec 13, 2004
but you carry 04/05 agx's?
Old Dec 13, 2004
truehonda's Avatar
yes we do
Old Dec 13, 2004
nice nice
Old Dec 13, 2004
truehonda's Avatar
You know we have you covered bud.
Old Dec 13, 2004
yes you rock edward...
edspyhill09
Jun 12, 2016 02:45 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
oneheadlight
Apr 29, 2015 11:30 PM
viper775
Dec 9, 2001 10:52 PM
supercivic01
South
Nov 30, 2001 11:27 AM
