CEL map/baro low voltage detected?
Old Dec 10, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
what the heck does this mean?? thats the code i got from my car, but its making it go into limp mode... so my top speed has been limited to 63mph...
now im pretty sure the map sensor is good.. i just changed the o2 sensor...
but any ideas to what might be wrong?
i dont think theres a vacuum leak, at least i dont hear one
Old Dec 10, 2004
streetglower's Avatar
well thats the problem with your car, what is the code it through out? If no one responds later, I will get my service manual out and give you step by step instructions on what to test. It will be later this evening, I have school and work all day.
Old Dec 10, 2004
WannaBFast's Avatar
im not sure which code.. im sure it will turn on again...
Old Dec 10, 2004
WannaBFast's Avatar
the code is p0107
Old Dec 10, 2004
WannaBFast's Avatar
im going over it again.. and it sounds like it may be a vacuum leak.. but its hard to tell cause of the exhaust... would that cause that code?
Old Dec 10, 2004
dezod's Avatar
7thgen Power Maker
Did you recently turbo?
Old Dec 10, 2004
well PM me later And I will look in my service manual and tell you.
Old Dec 10, 2004
WannaBFast's Avatar
no turbo yet.... im slowly but surly putting on the old components...
i think its probablly cause of the cold weather and my SRI.... altho my AIT sensor could be bad too...
cause if i clear the code after the car is warmed up.. it will run just fine... interesting huh?
Old Dec 15, 2004
Zolutar's Avatar
From: Utah, while roaming Montana, Idaho and Wyoming
Zolutar is an unknown quantity at this point
baro sensor? try your Throttle position sensor, and if its that you need a new throttle body, granted mine is in an RSX but that was my problem with that code
Old Dec 15, 2004
WannaBFast's Avatar
the tps reads just fine according to my vafc2
alxz310
Jul 30, 2015 12:18 PM
cukaracha
30
Jul 26, 2015 12:01 PM
jzhartman
22
Jul 23, 2015 10:42 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Jul 12, 2015 11:54 AM
