CEL map/baro low voltage detected?
Prowlin' with a Purpose
what the heck does this mean?? thats the code i got from my car, but its making it go into limp mode... so my top speed has been limited to 63mph...
now im pretty sure the map sensor is good.. i just changed the o2 sensor...
but any ideas to what might be wrong?
i dont think theres a vacuum leak, at least i dont hear one
well thats the problem with your car, what is the code it through out? If no one responds later, I will get my service manual out and give you step by step instructions on what to test. It will be later this evening, I have school and work all day.
no turbo yet.... im slowly but surly putting on the old components...
i think its probablly cause of the cold weather and my SRI.... altho my AIT sensor could be bad too...
cause if i clear the code after the car is warmed up.. it will run just fine... interesting huh?
From: Utah, while roaming Montana, Idaho and Wyoming
baro sensor? try your Throttle position sensor, and if its that you need a new throttle body, granted mine is in an RSX but that was my problem with that code
alxz310
Jul 30, 2015 12:18 PM
jzhartman
22
Jul 23, 2015 10:42 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Jul 12, 2015 11:54 AM
