4ohm or 2 ohm sub
Old Nov 2, 2004
civic2uner's Avatar
4ohm or 2 ohm sub
I went to get my sub today and noticed they came in 2 or 4 ohm and I didnt know what the difference was or which one I needed to get. So can someone help me out on which one I need? Thanks
Old Nov 2, 2004
shmik1's Avatar
depends on wut amp u want to use
Old Nov 2, 2004
shmik1's Avatar
http://jlaudio.com/tutorials/wiring/index.html
this page will show you how to wire them, you need to know wut ohm load ur amp runs, or if you dont have an amp yet.. figure out what amp you plan to get to match ur subs w/it
Old Nov 2, 2004
civic2uner's Avatar
i have a 200w kenwood amp and it is to old to find out the specs on it. its a 2 channel so I am figuring it can handle a 4 ohm in a bridged mode. am i any where near being right?
Old Nov 2, 2004
shmik1's Avatar
hard to say.. i'd assume its safe bridged @ 4ohms..
Old Nov 2, 2004
civic2uner's Avatar
going by that link, i should wire it in a series and that will give me 4ohm load at the amp?
Old Nov 2, 2004
shmik1's Avatar
so you'd want dual 2ohm... and look up the wiring for 2ohm to get a 4ohm load on the amp..
Old Nov 2, 2004
shmik1's Avatar
yea... dual 2ohm in series = 4ohm load
Old Nov 2, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
yea, are those subs you are talking about dual voice coil DVC or not? If they're DVC you'd want 2ohm if they're SVC single voice coil, then you'd want 4ohm
Old Nov 2, 2004
ohiojosh78's Avatar
ps i'm sure if you type in the model number and google it you'll find the specs.
Old Nov 2, 2004
civic2uner's Avatar
so it would be safe to get the 2ohm sub; wire it in a series; then that would result in a 4ohm load at the amp. just dont want to go clipping and destroy my amp or sub.
Old Nov 2, 2004
civic2uner's Avatar
they are alpine type s dvc
Old Nov 2, 2004
shmik1's Avatar
clipping is from distortion if im correct on my terms, clipping is if you turn ur gain up all the way and push ur amp too much
Old Nov 2, 2004
shmik1's Avatar
yea i have a type s 2ohm+2ohm = 4ohm load and i had it running on a 200rms plate amp for my home stereo..
Old Nov 2, 2004
civic2uner's Avatar
oh, ok, well i just didnt want to destroy anything, anyway.
Old Nov 2, 2004
shmik1's Avatar
ur amp should have gain settings, just dont put ur gain up 100% and turn ur deck up all the way..
research on tuning ur amp but i believe it was said to put ur deck up about 3/4 the put the gain up until it sounds bad then turn it back down to where it still sounds good... i think thats how u do it but im not sure... ludlamtheory is the one to talk to, him n MegaHertz are the first to audioheads that come to mind
Old Nov 2, 2004
civic2uner's Avatar
the model # on my kenwood amp is kac-4285 if anyone can help me out cause i cant find jack.
Old Nov 2, 2004
shmik1's Avatar
i dont think you have anything to worry about.. most amps have overheating protection and i dont think ur amp would have a min ohm load more than 4ohms, mine is 4ohm min.. meaning it will eventually hurt it to run 2ohm load.. but i HIGHLY doubt urs would be more than 4 ... so 4 should b safe..
ask around to ppl who know kenwood..
Old Nov 2, 2004
civic2uner's Avatar
cool, thanks man,
yea, i talk to mega all the time over msn, he is most helpful
Old Nov 2, 2004
shmik1's Avatar
well im'a go dude, good luck w/ ur stuff, if i was you i would just try it out w/ a 4ohm load, i cant imagine ur amp would have any prob and wiring @ 4ohm will b fine for the sub...
Old Nov 2, 2004
shmik1's Avatar
yea i'd get his opinion too if ur worried about it, just remember not to turn ur gain up all the way cause distortion will ruin ur sub
Old Nov 2, 2004
shmik1's Avatar
post pics once its in
later..
Old Nov 2, 2004
MegaHurtz's Avatar
You want 4 ohm if they are single coil, 2 if they are dual. You want to give your amp a 4 ohm load (I assuming you wanna bridge it), so if it's DVC (which I believe it is), dual 2 will give you a 4 ohm load
Old Nov 2, 2004
ohiojosh78's Avatar
or even dont bridge it. It will still draw the same current @2ohms x 2 as it would @4ohms x 1. It's just easier to wire if you're not sure of what to do.
JetsterDajet
52
May 8, 2016 12:11 AM
Bruce2
Sep 21, 2015 08:01 PM
alvinecigs
Air Conditioning
120
Sep 20, 2015 03:47 PM
Jul 12, 2015 11:54 AM
