4ohm or 2 ohm sub
4ohm or 2 ohm sub
I went to get my sub today and noticed they came in 2 or 4 ohm and I didnt know what the difference was or which one I needed to get. So can someone help me out on which one I need? Thanks
http://jlaudio.com/tutorials/wiring/index.html
this page will show you how to wire them, you need to know wut ohm load ur amp runs, or if you dont have an amp yet.. figure out what amp you plan to get to match ur subs w/it
i have a 200w kenwood amp and it is to old to find out the specs on it. its a 2 channel so I am figuring it can handle a 4 ohm in a bridged mode. am i any where near being right?
so it would be safe to get the 2ohm sub; wire it in a series; then that would result in a 4ohm load at the amp. just dont want to go clipping and destroy my amp or sub.
ur amp should have gain settings, just dont put ur gain up 100% and turn ur deck up all the way..
research on tuning ur amp but i believe it was said to put ur deck up about 3/4 the put the gain up until it sounds bad then turn it back down to where it still sounds good... i think thats how u do it but im not sure... ludlamtheory is the one to talk to, him n MegaHertz are the first to audioheads that come to mind
i dont think you have anything to worry about.. most amps have overheating protection and i dont think ur amp would have a min ohm load more than 4ohms, mine is 4ohm min.. meaning it will eventually hurt it to run 2ohm load.. but i HIGHLY doubt urs would be more than 4 ... so 4 should b safe..
ask around to ppl who know kenwood..
well im'a go dude, good luck w/ ur stuff, if i was you i would just try it out w/ a 4ohm load, i cant imagine ur amp would have any prob and wiring @ 4ohm will b fine for the sub...
You want 4 ohm if they are single coil, 2 if they are dual. You want to give your amp a 4 ohm load (I assuming you wanna bridge it), so if it's DVC (which I believe it is), dual 2 will give you a 4 ohm load
JetsterDajet
52
May 8, 2016 12:11 AM
Bruce2
Sep 21, 2015 08:01 PM
Jul 12, 2015 11:54 AM
