aftermarket head unit bezel
Old Oct 31, 2004
JP375's Avatar
JP375 is an unknown quantity at this point
Noob question...Here is a picture of the mounting kit from crutchfield for a aftermarket HU in a 2004 civic coupe. Do you really have to replace the whole piece with the storage pocket? The stock one has a door over it, I would like to keep this. Would I be able to do the install and just use the HU trim ring, but keep the storage pocket bezel stock? Please post pics of your HU's installed so I can see how others have done it.
Old Oct 31, 2004
Astrodriver's Avatar
Astrodriver is an unknown quantity at this point
there are actaully several different types of install kits...Metra makes 3 versions if i remember correctly....the one you have shown, one that has a cutout for an EQ, and the one that most people want which is the top piece only - that way you keep your stock pocket...keep looking...other stores and stereo shops carry just the top piece kit. I bought mine from a local stereo shop. They were actually the third store i checked out...the first two only carried the one you have pictured
Old Oct 31, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Yea when i had my headunit installed by bestbuy they gave me that crappy one ^^^. Later i found the metra one that lets you use the pocket w. door. I would definilty suggest tryin to keep it.
Old Oct 31, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
check out this part http://www.partsexpress.com/pe/showd...number=265-668
Old Oct 31, 2004
MegaHurtz's Avatar
The correct kit to keep the stock pocket w/little door is the Metra #99-7897, which is the same one that tbaleno posted.
my HU install:
Old Nov 1, 2004
JP375's Avatar
The metra kit you guys show is exactly what I'm looking for. One thing though...if you look at Megahurtz install you can see a noticeable gap around the head unit. Is there another trim piece to fix this. Or is that going to vary depending on HU?
Old Nov 1, 2004
MegaHurtz's Avatar
The gap is nothing... the HU itself is very tight, but the face is slightly smaller so it leaves a small gap, but it's barely anything
Old Nov 1, 2004
MegaHurtz's Avatar
that doesnt look bad does it?
Old Nov 1, 2004
JP375's Avatar
I don't think it looks bad, but don't you think it would be nice to cover the small gap around the face? So why do they even make the kit with the pocket? Why would you want to replace more than just the top section?
Old Nov 1, 2004
MegaHurtz's Avatar
can't put any trim in there, the fit IS quite tight, my faceplate release button is in the top left corner and it's really hard to push to get the face off
not all 7th gens have the pocket
some have 2 units
some i dont know waht they have, maybe a blank panel or maybe a stock pocket without cover
Old Nov 1, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
I may switch mine back to the stock bezel - the aftermarket I have tends to vibrate a bit at times which makes it annoying...
Old Nov 1, 2004
tripledoublegs's Avatar
Euro-Spec
I want the metra kit, but I can't find my stock pocket anywhere...grrrr
Old Nov 1, 2004
MegaHurtz's Avatar
They should make a full size kit that includes the pocket or include a din sized accessory with a pocket with a door then you can just use the double din kit and the pocket accessory
Old Nov 1, 2004
Bires's Avatar
Bires is an unknown quantity at this point
This post would have been really handy last week before I ordered the kit with the pocket (no door). I wonder if I can cut and dremel the bezel once it comes...
Old Nov 1, 2004
MegaHurtz's Avatar
sell the kit or return it and get the right one, dremeling it will probably make it end up looking all horrible and uneven unless you are skilled with it
Old Nov 1, 2004
memorex's Avatar
memorex is an unknown quantity at this point
Is the radio and this bezel the only thing I need for a clean new HU install? Don't know much about that stuff, but I am going to be putting in a new HU. not looking for a system, just a new HU..
Help me out here..
Old Nov 2, 2004
IronFist's Avatar
I have that one you posted. The pocket isn't deep enough for an entire CD to fit in. You have about 3/4" of the CD hanging out.
Old Nov 2, 2004
JP375's Avatar
Anybody else have pics of their installs using the Metra kit? I would like to see a couple more examples. I'm still not completely convinced that their isn't a larger than acceptable gap between the HU and the bezel.
Old Nov 2, 2004
Rufus's Avatar
I have one in "my ride" photos
Old Nov 2, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
damnit.. i want my lil door back... hmmm... damnit.. stupid bestbuy
Old Nov 2, 2004
tbaleno's Avatar
http://memimage.cardomain.net/member...328_1_full.jpg
The colors don't match because my console seems to change colors depending on the lighting conditions.
Old Nov 2, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
bs. i got the one w/o door
Old Nov 2, 2004
MegaHurtz's Avatar
bs what?
mugenca
Apr 16, 2015 12:15 AM
oblivious9
Jan 25, 2002 10:28 PM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
