Return of the Ghetto Installer (pics)...
Old Oct 31, 2004
fonto's Avatar
The LA Clipper
...pics:
Old Oct 31, 2004
thom's Avatar
/////ALPINE
nice
Old Oct 31, 2004
MegaHurtz's Avatar
Crown!!
nice man
Old Oct 31, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Ghetto? WHat's ghetto about that? I was expecting some amps sliding around in your trunk with 800 feet of extra wire all tangled about. That looks nice.
Old Oct 31, 2004
MegaHurtz's Avatar
I was expecting the ol power wire thru the door jamb trick
Old Oct 31, 2004
fonto's Avatar
The LA Clipper
Yeah, it looks good...but I have to keep up my reputation for the ghetto installs.
If you look at the side view, there is saw dust behind each screw because I was trying to get the amps lined up, and ended up drilling a bunch of holes. I also had to use longer screw because I could not get the nice screws that came with the amp to hold because I had drilled into the wood too much. The is also a small hole just about the top left corner of the amp from where my cap wiring used to be...and the last ghetto thing is that the RCAs are crammed right between the power wires...good thing that amp isn't for the highs
Old Oct 31, 2004
fonto's Avatar
The LA Clipper
haha...I did that with my wife's car
Old Oct 31, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
LMAO i just saw that at Walmart today. Hmmmmm...seems like i always see that at walmart.
Old Oct 31, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
it looks good, nothin like i expected when i saw the title...nice job
Old Oct 31, 2004
fonto's Avatar
The LA Clipper
I don't know if yall would want a review of he amp in another thread, but so far so good. The DBO feature is an interesting take on a subsonic filter. The thing that sucks is that the DBO is not defeatable...so this amp seems to be more applicable to ported applications at 25 hrtz and up.
The birthsheet says 1210 @ 4ohms and 1170 @ 1 ohm.
The really usually thing is that I no longer have cancellation at 90 hrtz, BUT my subs do not play flat between 35-65 hrtz like before (I can't really explain because this should be box dependent, and I haven't even changed the box. Although I may have slightly moved my box when I removed it. Maybe it adjusted the frequency response). My subs are ported to 30 hrtz, but now it peaks at about 50 hrtz and goes down by about 3 dbs between 35-40 hrtz. The good thing is I can prolly use the DBO to flatten out the response.
Old Oct 31, 2004
MegaHurtz's Avatar
lmfao what were you doing at walmart?
Old Oct 31, 2004
fonto's Avatar
The LA Clipper
Whats wrong with Walmart? I wish there was a Walmart in LA!
Old Oct 31, 2004
Mr.Modify's Avatar
damm that's nice.
Old Nov 1, 2004
J187's Avatar
Oh, well welcome back GI (ghetto installer) Fonto! Good of you to explain your installs goofs. Who cares, looks sweet. I would still take advantage of those clear-faced amps begging for some LED accents.
Old Nov 1, 2004
fonto's Avatar
The LA Clipper
Each one actually has two holes for neon tubes...but I don't know if I want to do that right now.
Old Nov 1, 2004
shmik1's Avatar
walmart is the best, they have almost everything.. of course they have nothing if you always wanna buy high end.. but they have all sorts of good VALUE stuff.. ie price/quality ratio..
Old Nov 1, 2004
tripledoublegs's Avatar
Euro-Spec
that looks very nice...
clean setup
Old Nov 1, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
that is some serious ghetto crap work you have done
umm... wanna do the same thing to mine?
Wild Cranker
427
Jan 28, 2016 06:49 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
toastyghosty
32
Dec 26, 2001 02:03 AM
ImmortalEX
Nov 8, 2001 09:52 PM
