My Low Beams Do Not Work....
Old Oct 24, 2004
IrockCivics's Avatar
Like 2days ago I was driving at night and I noticed that my lights were off and only my high beams worked. Today I went to Autozone and bought another pair of light bulbs and I just finished putting them on my car, and again my low beams dont wanna go on, just the high beams work. Anyone know what could be wrong? I checked the fuses, and the wires are not melted and everything else looks ok. I need my lighs so I can drive at night. I hope someone can help me out. Thanks as always.
Old Oct 25, 2004
gh0st's Avatar
TAQUITOS!!!!
is your car still under warranty? bother honda if it is
is it both sides?
Old Oct 25, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
There was a recall on the light switch. Did you have it fixed? If not take the car to the dealer and they will fix it for free.
The recall was on the switch going bad and the low beams would quit working. Pretty much all 2001's had this problem.
Old Oct 25, 2004
yeah I remember when they sent me that letter will they still fix it even tho' I have aftermarket bulbs on my car?
Old Oct 25, 2004
ImPulse's Avatar
Depends on the dealership... I would go and if they say no, yell
Old Oct 28, 2004
Ok, Well Today I Brought My Car To The Dealer, And They Said My Aftermarket Blue Bulbs Burned Out The Switch. I Don't Really Know About What Switch They Are Talking About, But They Said I Will Have To Pay $755.28 To Replace The Lenses, And Wires And Something Else, I Forgot What Else They Said. They Did Replace The Switch For Free Because Of The Recall Notice I Received. Anyway, Now They Are Saying I Have To Pay All That Money To Fix Those Things, And I Cannot Put The Lights On Until Those Are All Replaced. Should I Replace The Blue Bulbs With The Stock Ones, Or Keep The Blue Ones? Is The Dealer Right With What They Are Saying? When I Returned Home, I Put The Lights On And Everything Works Fine. Thanks A Lot Everyone.
Old Oct 28, 2004
pon55's Avatar
Look at it!! Is the wire burned,are you using 100+ WATT bulbs? Are your lenses or light sockets melted?
I smell dealer bullshit!
Could be wrong,I was once!
Old Oct 28, 2004
Nothing is burned or melted, and I am using 60/55W Halogen bulbs. Everything looks fine. Nothing smells burnt, or anything. Thanks for your post pon55.
Old Oct 28, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
if everything works.. keep it..
id make a note of what they replaced incase it happens again.. if it does something is messed up with yer aftermarket lights so you may wanna have someone (other than the dealer) check it out..
Old Oct 28, 2004
The color of the bulbs means moose poop. For all of you, Moose poop is a huge pile of crap.
The wires do not know what colored bulbs are plugged in. They only feel the current pulled through them! So if the wattage on your bulbs is 55w low and 60w high, then nothing is changed. In essence you replaced the bulbs with oem spec bulbs, just a different color. If you put Sylvania, no name, or any other brand of bulbs besides HONDA bulbs, they would still pull 55 watts low beam.
The only way to burn out your wires is to use higher wattage bulbs, which would pull excessive current on the wires and possibly burn them.
If nothing is burned, if the lights work fine, and the bulbs are 55/60, then relax, don't worry, be happy.
The damn switch was defective, and instead of just replacing it and going on with life, they tried to get some more money. Makes me ashamed to work for Honda.
Write a letter to the district manager and ask if replacing your bulbs with stock replacements is bad for your car. Just because you did not replace your bulbs with OEM ones is not good enough to destroy your car. If that were the case, you would have to use HONDA everything.
The only thing I always use that is Honda is HONDABOND gasket material and HONDA transmission fluid. But they are better, so they are worth it.
Old Oct 28, 2004
Thanks to both of you, againifall, and rickinthescv. I honestly dont know what to do. I will write the letter to the DM.... and see what he says. I will also check Honda sites, and see what they say about it. Thanks for all your help. I appreciate it a lot.
Old Oct 28, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
i would go to a different honda dealer if possible, that one is just trying to rape you in teh wallet, i had AFTERMARKET headlights and BULBS, and my dealer.. one of 4... replaced the switch.. it took a whole day, but they still did it for free.. PLUS gave me a ride to work
the lights cant burn out the switch cause the lights are on a relay with the switch.. and are 2 separate circuits
Old Oct 29, 2004
Yeah imma try to go to another honda dealer.... Well this morning I got up to take my mother to work and the lights were working fine and like 10mins past and the lights turn off again so I had to drive with my high beams on I dont know what the hell is the problem I checked the lights and nothing was burnt everything looks ok, I dont know what to do now.
This is what my dealer put on the receipt : HEADLAMPS INOP/ REPORT CUSTOMER HAS AFTER MARKET HEADLAMPS AND BULBS MY HHAVE CAUSED HEADLAMP SWITCH TO BURN OUT!!!!!!!!!
CraigW
Aug 18, 2015 07:06 AM
JetsterDajet
Aug 16, 2015 01:56 PM
Doug Lassiter
Aug 9, 2015 09:31 PM
adamdrives
15
Aug 8, 2015 08:53 PM
alxz310
Jul 30, 2015 12:18 PM
