When people make custom pods and enclosures for their cars...
Old Oct 23, 2004
IronFist's Avatar
What are they making it out of and how do they mold it?
Old Oct 23, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
lots of fiberglass and sanding
Old Oct 23, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I'm in the middle of building fiberglass kick panels..
Fleece, wood, fiberglass matte, fiberglass resin, bondo-glass, and bondo..
Old Oct 23, 2004
PunkingCivic's Avatar
I need TP for my bunghole
Here is a site with stagged photos of a wrx setup.
http://tiger.towson.edu/users/jbrigh2/subwooferbox.html
Old Oct 23, 2004
here is another:
First step was to tape off the work area.
This is the enclosure after a couple layers of fiberglass resin and cloth.
After applying about four layers of fiberglass then remove it from the trunk and added a few more layers to ensure that it was stong enough.
This is the mounting ring for the Sub.
Here's the fleece forming the front side of the Enclosure.
After applying a few more layers over the fleece, spread body filler over the entire surface.
Here you can see the sound deadner that sprayed on the inside.
Final product.
[img]
Old Oct 23, 2004
IronFist's Avatar
^ Thanks for posting those images.
What's bondo?
Old Oct 23, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
IronFist
7thGen Junkie Join Date: Jul 2002
Posts: 10,476 | Points: 65871.30 (Donate)
Trader Rating: (3)
aslkhfaoihdvkjnasf!!!
Old Oct 23, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
how many cubes did it turn out to be punkincivic
Old Oct 23, 2004
Ed's Avatar
Ed
that's exactly how i built mine. Bondo's like this cream that you put hardener in and it hardens up very quickly. It sands down very smooth. It's typically used for auto body repair.
Old Oct 24, 2004
And Bondo-Glass is a mixture of bondo with fiberglass strands in it for strength. It's kind of a way to make the whole process go faster because you don't need to lay down as many layers of fiberglass.. although I guess I would recommend more layers anyways just because it makes me feel better haha
Old Oct 24, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Fiberglassing is a tough process to learn. I'd recommend you do several practice pieces before you attempt one inside the car. Also, it's a good idea to apply a wax or release agent on the tape, as some masking tape tends to stick to the glass. Also, bondo is a body filler. It is used to fill imperfections in the surface. I prefer dynalite in an ICE application, as it's a little thinner and smoother. Less work is better no?
Old Oct 24, 2004
One more suggestion I have is when applying the resin on the fleece (first layer) is that you pour the resin on as opposed to brushing it on as it saturates it quicker and better.
Old Oct 24, 2004
IronFist's Avatar
Originally Posted by againifall
IronFist
Trader Rating: (3)
Why would you post that in this thread?
GolNat
Suspension DIY
May 12, 2022 06:49 AM
usajags84
May 10, 2015 08:11 AM
Bigdaddy198
Apr 30, 2015 08:36 PM
djdefcon
17
Apr 6, 2005 11:52 PM
