SF Pressure Sensor/Fuel Pump Question
Until I'm ready to up my boost beyond 4psi and hook up the alcohol injection wires, I was wondering is it safe to use the pressure sensor that I received with my alcohol injection upgrade to turn on the fuel pump at 0.5psi? Can it be adjusted to that low a setting? I'm also wondering if the allen screw will stop when it reaches 0, or will it continue on to sense vaccum?
It will not sense vaccum. But to turn it down to run the fuel pump, basically you keep backing it out until you hear it start to rattle when you shake it. That is a great starting point.
yeah, after burning up 3 pumps....i am gonna buy a another hobbs switch to run my pump
at $100 a pump, i can't afford to keep doing this
Originally Posted by CivicMexicano
Cuz, the pump is always running, no matter what, that one way of butning it, cuz theres no way of cooling it.......
Or bad wiring or ground.....
the last pump i installed had a toggle swtich so i can turn it off when not boosting and a 30 amp inline fuse installed. It lasted about 50 miles
I believe there is something wrong with my FMU........how come other ppl have no problems
thana
Jun 15, 2020 07:05 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
mrcell24
May 19, 2015 10:02 AM
