SF Pressure Sensor/Fuel Pump Question
Old Oct 15, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
Until I'm ready to up my boost beyond 4psi and hook up the alcohol injection wires, I was wondering is it safe to use the pressure sensor that I received with my alcohol injection upgrade to turn on the fuel pump at 0.5psi? Can it be adjusted to that low a setting? I'm also wondering if the allen screw will stop when it reaches 0, or will it continue on to sense vaccum?
Old Oct 15, 2004
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
It will not sense vaccum. But to turn it down to run the fuel pump, basically you keep backing it out until you hear it start to rattle when you shake it. That is a great starting point.
Old Oct 15, 2004
civic01vtec's Avatar
yeah, after burning up 3 pumps....i am gonna buy a another hobbs switch to run my pump
at $100 a pump, i can't afford to keep doing this
Old Oct 16, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
so when you shake the sensor it and it rattles thats the lowest point where the switch sees pressure??
Old Oct 16, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
How did you end up burning 3 pumps ???
Old Oct 16, 2004
Cuz, the pump is always running, no matter what, that one way of butning it, cuz theres no way of cooling it.......
Or bad wiring or ground.....
Old Oct 16, 2004
the last pump i installed had a toggle swtich so i can turn it off when not boosting and a 30 amp inline fuse installed. It lasted about 50 miles
I believe there is something wrong with my FMU........how come other ppl have no problems
Old Oct 16, 2004
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
yeah., i have no probs with fuel pump ever... hmmmmmm,,,,
thana
Jun 15, 2020 07:05 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
mrcell24
May 19, 2015 10:02 AM
dano2005
Apr 14, 2015 01:58 AM
viper775
Dec 9, 2001 10:52 PM
