Bandpass to sealed
Old Oct 12, 2004
ComPort X's Avatar
ComPort X is an unknown quantity at this point
Bandpass to sealed
Would moving 3 10's from a bandpass box to a triple 10 sealed box make any improvement's in sound? Only thing is I am not sure the specs on the sub's or the requireded air space. Since I have the sealed box just laying around, I thought I would see what you guys thought.
Old Oct 12, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
I'm not going to sit here and type a bunch of stuff cause it's lengthy to explain the characteristics of each, so I'll just cut and paste the characteristics from JL's website ( www.jlaudio.com) and let you read through them and maybe it'll help explain their purpose a little better for ya.
Bandpass:
These enclosures seem to be the latest rage in the car audio world. It would probably surprise many people to know that these designs have been around for many years. The first patent for a bandpass enclosure was filed in 1934 by Andre d'Alton. In the last ten years, interest has been renewed in these enclosure designs and substantial strides have been made in defining their behavior. Many home sub/satellite speaker systems currently use bandpass designs for low-frequency reproduction. Designs from Bose, KEF, AR, and many others have become very popular in home audio circles.
In a bandpass box design, the woofer no longer plays directly into the listening area. Instead, the entire output of the subwoofer system is produced through the port or ports. In a conventional sealed or ported subwoofer system the low-frequency extension is controlled by the interaction of the speaker and the enclosure design, but the high frequency response is a result of the speaker's natural frequency response capability (unless limited by a crossover.) In a bandpass enclosure, the front of the speaker fires into a chamber which is tuned by a port. This ported front chamber acts as a low-pass filter which acoustically limits the high- frequency response of the subwoofer system. The name "bandpass" is really pretty descriptive in that it refers to the fact that the enclosure will only allow a certain frequency "band" (range) to "pass" into the listening environment.
So what? Couldn't the same thing be accomplished by placing a low pass crossover on the subwoofer system? Yes, it could, but a bandpass enclosure can produce significant performance benefits in terms of efficiency and/or deep bass extension that would not be possible in conventional designs of equal size.
By adjusting the volumes of the front and rear chambers and the tuning of the port or ports, significant performance trade-offs can be created. When box parameters are adjusted for a narrower bandwidth, the efficiency of the subwoofer system within that bandwidth increases and can reach gains of up to 8dB (sometimes even higher.) As box parameters are adjusted for wider bandwidths, very impressive low-frequency extension can be produced from extremely compact enclosures at the expense of efficiency and good transient response. Intermediate bandwidths can also be designed which create a compromise between all these characteristics. As if that is not confusing enough, within each bandwidth range, the designer can also manipulate box parameters to shift the range of operation up or down the sub-bass range which also has an effect on efficiency.
As you can see, bandpass enclosures can have very different sound characteristics based on the designer's choice of box parameters. As such, it is not always possible to make blanket statements as to the performance benefits and drawbacks of bandpass enclosures in general.
One characteristic of bandpass enclosures which is universal is that they exert greater control over cone motion over a wider frequency band than conventional designs. Due to controlled, rapidly changing air pressure on either side of the woofer, the woofer is capable of producing high levels of acoustic output without physically moving very much. This means that the woofer is less likely to encounter excursion limits in the main part of the sub-bass range. However, just because the cone isn't moving as much doesn't mean that the speaker's motor assembly isn't still trying to drive the cone hard; it just means that the speaker cone is encountering resistance to motion. This resistance can be very hard on speakers, especially when crazy car audiophiles are at the controls. The conflict between the force generated by the motor assembly and the air pressure in the enclosure can impose extreme stress on the glue joints and suspensions of the woofers. You can literally tear a speaker apart in a bandpass enclosure if you apply too much power. Because the speaker is not moving as much and because noises are masked by the front chamber, it is also very difficult to hear when a woofer is in serious trouble. Many people have been known to crank bandpass enclosures up and blow the speaker to bits within a few minutes because they did not realize that the speaker was having a heart attack. Choosing the right amount of power and carefully setting amplifier gains is very important in order to ensure long- term reliability.
Bandpass enclosures can be divided into two basic types: single- reflex and dual-reflex. In a single-reflex design, the rear chamber is sealed and the front chamber is ported. In a dual-reflex design, both front and rear chambers are ported into the listening area. A variation of the dual-reflex and single-reflex, known as "series-tuned," has a port which connects the rear and front chambers.
The differences between single-reflex and dual-reflex bandpasses are similar to the differences between sealed and ported enclosures. A single-reflex typically exhibits a shallower low-frequency roll- off rate (approximately12dB/octave) and better transient response. A dual-reflex is more efficient and controls cone-motion over a wider range but typically has a sharper (18-24dB/octave) low- frequency roll-off. Because of the difference in low-frequency roll- off rates, a dual-reflex usually has to be larger in size to produce the same low-frequency extension as a single-reflex design.
As compared to more conventional enclosure designs, bandpass enclosures are very complex to design and build. The rules governing the performance of bandpass enclosures leave no room for error. Slight volume miscalculations or sloppy construction can turn a good design into a poor-performing box. Integrating the proper size port or ports can be extremely challenging and often renders designs that looked great on paper completely impractical. The design of these boxes should definitely be left to people with extensive enclosure- building experience.
Sealed:
The sealed (aka: air-suspension, acoustic-suspension) enclosure is a classic box design. Patented in 1949 by Harry Olson and popularized in the 1950's by Acoustic Research, this design has stood the test of time and has been adopted by many home and car audio companies.
In a sealed enclosure, the woofer is tightly controlled by a trapped volume of air in the enclosure which acts as a spring (hence the name "air-suspension.") The woofer must literally pull the air with it as it moves outward thus decreasing the air pressure inside the box and compress the air inside the box when it moves inward, which increases the air pressure inside the box. Since the air pressure inside the box seeks to equal the barometric pressure of the atmosphere, it acts as a controlling force over the motion of the speaker. The more the speaker moves inward or outward, the greater the pressure exerted by the air-spring of the sealed enclosure in the opposite direction.
The relationship between the parameters of the speaker being used and the volume of air inside the enclosure dictates the performance of the sealed subwoofer system. By making the box larger, the air spring limits cone motion less and allows the system to play lower and with flatter overall response (lower Qtc) at the expense of power handling. If you go too large, however, you begin to lose efficiency in order to gain the additional low frequency extension. By making the box smaller, the air spring exerts more control and limits cone motion at low frequencies which increases power handling but does not let the system play as low and produces a more peaked response (higher Qtc.) For any speaker competently designed for sealed box applications there is a range of enclosure volumes that will produce good high-fidelity sound. Changing the enclosure volume within that range can fine-tune the response to suit the tastes of the listener and/or the acoustic properties of the vehicle
Old Oct 13, 2004
tripledoublegs's Avatar
Euro-Spec
^^damn, thats some good info
Old Oct 13, 2004
LudlamTheory's Avatar
i boogie for the raindrops
short version: it wont play as loud, it wont play as low, but it wont sound as boomy and itll be a lot more transparent
Old Oct 13, 2004
ComPort X's Avatar
I would kinda like a little better sq, and the loudness wouldn't matter if the overall sound was better.
Munzy
21
Oct 7, 2015 07:48 AM
Elciteeve
Sep 28, 2015 12:40 PM
Sep 27, 2015 11:33 AM
speedlever
Sep 24, 2015 07:18 PM
Rexall
Sep 11, 2015 02:30 PM
