PreOuts vs. amp inputs (this won't be a problem, right?)
Old Oct 12, 2004
IronFist's Avatar
Ok, so I ordered the Pioneer DEH-P8600 because it had 4V preouts. My amp can take a max of 5V input. I get my head unit today and they sent me the Premier version instead. Oops. The Premier version has 6.5V Preouts instead, which is specifically why I ordered the non-Premier version in the first place.
So I called MTX (the company who makes my amp) and asked if this would be a problem. I said "my instruction manual for your amp says a max of 5V input, but this head unit I have puts out 6V." He said "the 6V is the max if you turn it up all the way. As long as you keep it below that you'll be fine."
Is that true?
I don't want to have to send this head unit back. Does PreOut voltage really vary with high you have the volume?
Thanks.
Old Oct 12, 2004
MegaHurtz's Avatar
yes.
Old Oct 12, 2004
MegaHurtz's Avatar
just like speaker output, signal output will vary with volume and start to distort when it gets past a certain point
Old Oct 12, 2004
IronFist's Avatar
So, "yes" it's fine or "yes" it will be a problem?
Old Oct 12, 2004
MegaHurtz's Avatar
yes fine
Old Oct 12, 2004
IronFist's Avatar
Thanks.
Old Oct 12, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Just turn the gains down on the amp to match the deck. That is why they are there.
Old Oct 12, 2004
IronFist's Avatar
I leave my gain relatively low anyway.
What do you mean "to match the deck?"
Old Oct 12, 2004
MegaHurtz's Avatar
To match the signal output of the deck.
Put your gain as low as it can go. I should have mentioned that before.
Old Oct 13, 2004
IronFist's Avatar
Gain on the amp, right? I have it pretty low anyway. Thanks.
Old Oct 13, 2004
tripledoublegs's Avatar
Euro-Spec
Great HU. You should be glad you got the Premier version. That ****'s top of the line Pioneer...(Don't like the 960 version )
Old Oct 13, 2004
MegaHurtz's Avatar
Set your gain as low as it possibly can go, like turn the setting to 0. Best way to run your amp
I am just glad that you did the homework on your amp and found out what the input sensitivity was, good work!
Old Oct 13, 2004
IronFist's Avatar
^ Thanks. I'll let you know how the install goes.
Old Oct 13, 2004
MegaHurtz's Avatar
Oh I'm sure u will
Old Oct 13, 2004
Sweet! They sent me the premier of mine too over regular. I sure wasn't complaining.
Old Oct 13, 2004
MegaHurtz's Avatar
As long as you pay the same, what is the diff if they grab something better off the shelf?
Old Oct 13, 2004
IronFist's Avatar
Indeed. I don't like the 960, either, because you have to lower the front part in order to see the display. The funny thing is I could have gotten the 960 for less than the 860, but I didn't want it. hehe.
roverben
Jan 21, 2019 05:16 PM
Wild Cranker
May 19, 2015 06:10 PM
dosmastr
May 5, 2015 12:19 PM
cable
Dec 17, 2001 06:14 PM
PimpBot5000
Nov 26, 2001 07:15 PM
