ICE Report Card (A thru F)
Old Oct 12, 2004
mattnyc's Avatar
mattnyc is an unknown quantity at this point
- Alpine 9831 Headunit
- Infinity Reference 6000cs front components 90W RMS@4ohms
- MB Quart PCE 164 Midbass driver system for rear deck 60W RMS
- Amp Kenwood KAC-8401 60x4 @4ohms
Setup inspired by this article on the web. I wanted to do all MB Quart but not many speakers will fit the front door housing without modification; crutchfield confirmed the stock speaker housing was 1.98"!! But the Infinity was the best out of the ones that could fit and came in a mount depth of 1.937". Kenwoods came in at 1.936. I tried rockford and kenwood 605 myself and not a fit. but the Reference 6000cs should be ok
What do you guys think of the above setup? I am not going to add a sub so i need to get all my sounds from these 4 speakers and two tweeters. I am hoping the sound will be great. Any feedback is appreciated.
Old Oct 12, 2004
brash's Avatar
brash is an unknown quantity at this point
FWIW modification is not hard. You can add a 1"+ spacer pretty easily, which gives you are lot more options. For some speakers (depending on the magnet size) you may also need to cut the metal, which is not hard if you have a dremel tool or can borrow one.
Old Oct 12, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Yeah and the reference 6000cs mount depth is 2-1/16".
As far as modification, you can actually buy spacer rings pre-made if you don't wan't to make them out of MDF, opens up your options immensly
Old Oct 12, 2004
mattnyc's Avatar
I really dont want to put spacers or modify the hole. What speaker will fit without modification and sound good with my amp and rear mb quarts?
Old Oct 12, 2004
MegaHurtz's Avatar
AFAIK pretty much ANY aftermarket speaker requires a spacer. There is virtually no mounting depth available without one, and every aftermarket speaker install I've seen in a 01-04 Civic uses them, so IMO there is no other option. We are not talking about modifying the car, you simply snap a spacer in and screw the speaker into the spacer... no big deal.
Old Oct 12, 2004
brash's Avatar
Actually, there are several aftermarket speakers that would not require spacers.
That said, I don't know of any that I'd recommend.
Old Oct 12, 2004
MegaHurtz's Avatar
Well because of the odd shape of the hole, you might want to consider a spacer anyway, as having that open space at the bottom where the hole is square-ish might have a negative effect on the sound quality of your speaker.
Old Oct 12, 2004
mattnyc's Avatar
What about these, 1 7/8 mounting depth.
http://www.cardomain.com/item/INFREF6002SI
And add some mb quart tweeters
Old Oct 12, 2004
MegaHurtz's Avatar
Those get my
But still consider what I said about spacers
Old Oct 12, 2004
mattnyc's Avatar
And lastly what tweeters are a good buy?
Originally Posted by MegaHurtz
Those get my
Old Oct 12, 2004
MegaHurtz's Avatar
Can't go wrong with MBQ, although with those particular Infinity speakers u should not need tweeters
Old Oct 12, 2004
mattnyc's Avatar
If nto tweeters, would these fit into the metra kit bottom compartment? and would you guys recommend this center speaker?
http://www.crutchfield.com/S-Cr7nvy0...900#morephotos
Old Oct 12, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
You really should use a spacer, I have MB Quart PSD's in the front with nothing but a spacer.
THose infities will still need a spacer. Most baskets dont clear the hole
Old Oct 12, 2004
mattnyc's Avatar
What year is your car? Is it the same as the 2004 civic sedan mounting spec? If you use a space was there any issue getting the door panel back on?
Old Oct 12, 2004
Mystic3030's Avatar
The door metal is the same, but I have an 02 coupe.
There is about a 1/4" gap on the very bottom of the door, however you dont see it or notice it at all unless you run your fingers along the bottom of the panel
solarpunk70
Apr 12, 2016 11:43 AM
IronFist
Sep 25, 2015 07:13 PM
speedlever
Sep 24, 2015 07:18 PM
