Sponsored by:
Sponsored by: CARiD
Ceramic Or Stainless Steel????
Old Sep 23, 2004
LowRYda03ex's Avatar
LowRYda03ex is an unknown quantity at this point
My friend has stainless steel DC sports headers in his acura, and he ordered ceramic. He thinks he got some good *** deal but i heard ceramic was better for heat insulation in comparison to the ss. Any knowledge and wisdom on this issue would be much apreciated. thanks
Old Sep 23, 2004
thom's Avatar
/////ALPINE
ceramic???
wth! lol
Old Sep 23, 2004
Are you saying you have never heard of ceramic headers or that they are better???
Old Sep 23, 2004
Ceramic looks better and insulates heat imo. You could always get them jet coated as well.
Old Sep 23, 2004
Thanks gearbox i love you. You are so knowledgable
Old Sep 23, 2004
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
so ceramic or ss is better?
Old Sep 23, 2004
PlasmaGT's Avatar
My Baby Daddy
PlasmaGT is on a distinguished road
Header.
Old Sep 23, 2004
funny...
Old Sep 23, 2004
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
SS is more for show i think...
Old Sep 23, 2004
civicvtec1ps's Avatar
Search and Learn
Ceramic might crack over time, but i perfer Ceramic over SS.
Better heat insulation.
You can always use heat wrap but it will void warranty.
Ceramic headers are cheaper than stainless.
Old Sep 23, 2004
02ciVike's Avatar
02ciVike is an unknown quantity at this point
Ceramic will insulate better then stainless steel, true, but you are still better off thermal wrapping the header. A HP or Kamikazi header will yield better horsepower results then DC sports. The piping on the DC sports header for the EX has little to no advantage over stock due to its small diameter.
Old Sep 23, 2004
Are there any negatives to heat wrap, other than it looking stupid?
Old Sep 23, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
gearbox- it gets fiberglass **** all over your hands.
the ceramic is cheaper because all it is, is a coated mild steel. I would choose a SS over the "ceramic" header for longevity. Simply wrap the pipes with a thermal wrap or put a heat sheild on top of it.
Old Sep 23, 2004
cdmx's Avatar
a ceramic header will break if you hit it with a hammer i bet
So uh stainless steel
Old Sep 23, 2004
You'll just chip off the ceramic coating.
Old Sep 23, 2004
Oh come on. The header is still metal, and ceramic refers to a coating. If the header was entirely ceramic, you could make one out of clay lol!
Any way to mod the stock heat shield to put on an aftermarket header?
Old Sep 23, 2004
yea im sure you could. It just bolts to the top two mounting bolts on the head so it shouldnt be to difficult to adjust it slightly.
Old Sep 24, 2004
dru106's Avatar
ThE CoRRupToR
ceramic coated is always better!!! NEver get stainless cuz over time it turns purple and looks nasty!!
Old Sep 24, 2004
How much expirence with stainless have you had and in what application? And no, ceramic coated is NOT always better.
Old Sep 24, 2004
So i guess we have come to the conclusion that ceramic is better for heat insulation, therefore inducing better performace results, however it is less durable than stainless steel, so either way you will have your pros and cons. I have another question about headers, though. What exactly would just an independant header do for performace? The piping is slightly wider so i would guess more air flow, but would it really only make a difference if you have an aftermarket performance exhaust system? It seems to me that each would be dependant on each other in order to work efficiently.
Old Sep 24, 2004
It would really only matter if your cylinder head exhaust ports were widened. Otherwise, the new header won't do anything. It might even make things worse since exhaust gas flows faster through the smaller stock pipes.
Old Sep 24, 2004
however, there is a certain velocity that creates excessive drag inside of smaller pipes so you have to properly size the runners in order to have a "happy medium" if you will.
twd000
Oct 4, 2015 12:52 PM
Islesfan
Sep 29, 2015 03:42 AM
Shadowbandit
Wheels and Tires
Sep 16, 2015 09:34 PM
powman02
Sep 15, 2015 07:38 PM
junkyardguy
Sep 2, 2015 06:07 PM
