my left rear window wont roll down
Maybe the switch just broke. Take it apart and see if the white little piece under the window button is broken. It's very sensitive and has to be exactly in the right place to open the window. Maybe it just got knocked out of place.
my driver side front window
my driver side front window make a wierd cranking noise when ever i use the automatic window down, you know when just have to hit the switch once and it automatically goes down.
I was wondering should I grease it up or any suggestion?
For you window easiest is if still under warrenty take it back.
However to check you switch and the connection on the problematic door get a electrical tester (looks like a screew driver with a light bulb at the end) to see i any pwr is being transmitted
My drivers side switch died on me while I had all my windows down...
I knew the switch was screwd because a burning smell was coming from it.
~$40 down the drain from hondaautomotiveparts.com
Pudnite
May 9, 2015 07:51 PM
