Sick of Thermal Tweeter Protection
Old Sep 14, 2004
Rufus's Avatar
I can't stand it. I have my Diamond Audio Hex 6.5s and silk tweets running off of a JL 300/2 and those damn tweeters keep cutting out. I figured that even with inflated RMS numbers that I'd still get away without clipping. The gains aren't even halfway up. BICH!
Old Sep 14, 2004
MegaHurtz's Avatar
That's a massive amount of power to be giving components.
Your gain is not a volume control, it adjusts the sensitivity to your inputs depending on the line voltage. If your amp gain will adjust between .2 and 6 volts and you have a 6 volt signal, the gain should be set at ZERO. Gain is simply for adjust the amplifier to weaker signals so that it produces sound louder, it's not by any means a way to control the volume of the amp. Too high of a gain (which you may have) is bad for the amp and your speakers so at the very least check your signal voltage and work from there...
Old Sep 14, 2004
MegaHurtz's Avatar
grrrrrrrrrrrr i got a server too busy message after I posted that and thought I lost it, what a pain in the ***, I thought they fixed those problems
Old Sep 15, 2004
Rufus's Avatar
Funny, I called Diamond and they told me that I wasn't giving them enough power. Of course they told me they didn't like JL and thought that underpowering them was causing clipping.
Old Sep 15, 2004
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
yeah right^^LOL we need ludlam or whiterabbit in here to actually explain the theory, BUT i will tell you that that is an aweful lot of power to be giving a component set regardless, and i know that if you are really cranking on it then the thermals on the crossovers will cut out the tweets until they cool down. a solution may be to turn the tweet level down on the crossover if you can.
Old Sep 15, 2004
brash's Avatar
brash is an unknown quantity at this point
How high do you turn up your HU volume?
Old Sep 15, 2004
Rufus's Avatar
I have the IVA 900 which actually shows different levels of volume by color coding. I never turn it up past 28 (Head unit goes to 35). I'm not using deck power but intil the 31 band eq is in and my a-pillar tweets, I AM turning the treble to +1 which, I know, does aggrevate the situation. If you are all familiar with JL they use a feature that claims to put out a reliable amount of RMS regardless of impedance. Diamond thinks its all BS. I agree that it should be enough power. I've heard of installing automotive lights in place of the resistor in the crossover to help it absorb more power. I dunno if it's fact or fiction, but I'd rather solve it logically first.
Old Sep 15, 2004
WhiteRabbit's Avatar
im kinda curious about this equipment you have.
so just the tweeters cut out? is this a component set with some sort of protective circuitry on the passive crossover? so JUST the tweets cut out, and you keep your midrange?
just trying to figure out how everything is working in your car....
Old Sep 15, 2004
Rufus's Avatar
HU - Alpine IVA-D900
Front stage - Diamond Audio HEX 6.5s and silk tweets
Rear stage - Diamond M6 5.25 (mid only powered off rear fill from HEX component crossovers)
Subs - Diamond Audio TDX 104 (2)
Amps - JL 500/1 (subs)
JL 300/2 (F/R stage)
The 300/2 is not bridged and each channel goes to its respective side. The reason that I can tell that it's a function of the amp is that the tweet in either kickpanel go out at the same time. The crossovers are doing their function. The signal is being sent from the amp and both crossovers cut the tweets at the same time on different channels. The HEX series is Diamonds high end gear. So I'm a little stumped. At first I had noticed that the 300/2 was running hot and the thermal light and low impedance light were going off. Fixing the ground solved that issue, but not the tweets.
Old Sep 15, 2004
alex053's Avatar
find somebody shady down there to tell you how to bypass the tweeter protection. we told people all the time at mtx how to bypass it.
Old Sep 15, 2004
Rufus's Avatar
I've really thought about it but I don't know how far after cutting out that I risk melting the sheath on the tweeter wires.
Old Sep 15, 2004
auto84's Avatar
I R T3H 1338
umm maybe the crossovers are getting too little impedance (three pairs of speakers...the tweets, mids in the doors, and the "rear fill."!) Are they designed to run rear fill as well as the components? maybe you should try connecting the rears to deck power instead of the crossovers and see if that remedies your problem... just a thought, but heck, try it and who knows, i might have guessed right?!
Old Sep 15, 2004
Rufus's Avatar
Tried it already by disconnecting the RAF and it still did it.
Old Sep 15, 2004
auto84's Avatar
I R T3H 1338
crank the gains all the way down, the deck settings to zero across the board, and crank the volume, see if it still does it then, maybe?
Old Sep 15, 2004
so the JL 300/2 will cut off tweeter frequencies and still pass through mids and lows if it's circutry is triggered?
Old Sep 16, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
i'd guess fiction. the resistance of an incadescent light bulb will change with temperature. temperature depends on how much current goes through the bulb. with audio, current will not be constant unless if maybe you're playing a sine wave. the resistors in the crossover are calculated values. you cant have randomly changing resistance if it's an RLC filter. your frequency response would get messed up.
Old Sep 16, 2004
Ed's Avatar
Ed
I'm curious, how are you connecting the rear mids only to the system? Are you connecting them to the same place on teh crossover as where your front midbass drivers are connected?
Old Sep 16, 2004
kicker makes a crossover with incandescent lights that blink to the music.
Old Sep 16, 2004
turboslug's Avatar
Super Hoser
care to explain the theory behind it?
Old Sep 16, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
My crossovers have incandescent lights as well for the tweeter that come on during amp clipping. Not sure on the electrical theory behind it, but supposedly the filament in the bulb will blow before the tweeter does.
Old Sep 16, 2004
LudlamTheory's Avatar
i boogie for the raindrops
sir, youve yet to answer us:
re your rearfill mids hooked up to the passive crossover for the hex components in front, or do they have their own crossovers
Old Sep 16, 2004
alex053's Avatar
ya..his are run off the crossovers. diamond has a special section of the crossover for Rear Acoustic Fill (RAF)
those bulbs are tweeter protection.
Old Sep 16, 2004
Rufus's Avatar
YUp, sorry it took so long. The RAF has settings as well -6dB, -3dB, etc. They're set all the way down. But they ARE pulling power off the crossovers. Its still irrelevant since I tested it without them plugged in and still had the issue.
Old Sep 16, 2004
my only other guess is youre clipping them into protection.
Old Sep 16, 2004
doubledeuce2k2's Avatar
or maybe a short somewhere. just a possibility, make sure connections are good and wiring is sound. there's always plenty of moisture in our lovely doors.
you don't have a loud button turned on on the HU or anything either do you?
Old Sep 17, 2004
Rufus's Avatar
LOUD is not on and neither is the other MX feature on the Alpines. Crossovers are under the carpet (under the seats), and the speakers are in kickpanels.
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
carid
Sep 28, 2015 10:13 AM
meicalnissyen
Sep 25, 2015 12:12 AM
ZoSoIV
Sep 17, 2015 07:17 PM
Bikergofast
Sep 12, 2015 01:36 PM
