Problems with my with Turbo setup(orlando)
Old Aug 26, 2004
Pervera's Avatar
Pervera is an unknown quantity at this point
I have recently turbo charged my 7th gen civic and am having tunning isues. Sometimes when I stop at the light the car will shut off on me but turn back on with no problem. When I gun it after about 4,000 rpm it starts boging on me. I can't seem to get the s-afc to eliminate the problem. I think the problem lies somewhere in the fuel system. I have stock srt-4 injectors if that helps I think they are about 400 something cc. I am here in Orlando florida and as soon as I work the kinks I will be selling a kit.
Old Aug 26, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
are the injectors to only thing that you have done to your fuel system...are you sure that the car is "bogging" at 4000rpm, or cutting out cause of no fuel...give me some more details so that i can help you
Old Aug 26, 2004
civic01vtec's Avatar
do you have a check valve ?
Old Aug 27, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
how was your AFC wired
Mine use to bog wen i had it installed and took it back to the guy and he said one of the wires were crossed. He used the diagram of the DIY 7thgen. IT WAS WRONG!!
went back and fixed it and everthing was fine
Old Aug 27, 2004
Pervera's Avatar
It shouldnt be a problem with not enough fuel the injectors are a good size, and they are currently the only fuel upgrade I have. I am considering putting in a fuel return and a FPR next week. The problems I think might have to do with the tranny(auto) when you gun it it bogs but if you let it go through the gears everything goes runs smooth. As far as the afc install I used the wiring diagram that I found on this forum. The wierdest thing is sometimes when I turn the ac on the car shuts off or doesnt boost as well.
Old Aug 27, 2004
opto_isolator's Avatar
Edit - I can't read....
Old Aug 27, 2004
dezod's Avatar
7thgen Power Maker
UUUUMMMM. The AUTO tranny isn't meant to handle a romp from dead stop. Theres your problem.
Old Aug 27, 2004
ImportRacer2123's Avatar
K20 Member
I got smoked last night by my buddys EP I Defenitly need to get my VAFC II dyno tuned. I bog down right as VTEC kicks that was at 7psi too.
Old Aug 28, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
damn what are his mods?
Old Aug 28, 2004
gotti's Avatar
Check your spark plugs....seriously. That was my problem. One was blown...
Do you have a lot of blow by ?
Old Aug 29, 2004
VinylPlaya04's Avatar
VinylPlaya04 will become famous soon enoughVinylPlaya04 will become famous soon enough
His buddys EP has a homemade intake. and we will check the plugs.
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
cukaracha
Jun 8, 2015 05:41 PM
Rogelio Rey
May 24, 2015 08:30 PM
Supramk3
May 8, 2015 11:16 AM
mikevtec
May 3, 2015 01:36 PM
