Problems with my with Turbo setup(orlando)
I have recently turbo charged my 7th gen civic and am having tunning isues. Sometimes when I stop at the light the car will shut off on me but turn back on with no problem. When I gun it after about 4,000 rpm it starts boging on me. I can't seem to get the s-afc to eliminate the problem. I think the problem lies somewhere in the fuel system. I have stock srt-4 injectors if that helps I think they are about 400 something cc. I am here in Orlando florida and as soon as I work the kinks I will be selling a kit.
SRT-4 owner with 2MCHPSI
are the injectors to only thing that you have done to your fuel system...are you sure that the car is "bogging" at 4000rpm, or cutting out cause of no fuel...give me some more details so that i can help you
how was your AFC wired
Mine use to bog wen i had it installed and took it back to the guy and he said one of the wires were crossed. He used the diagram of the DIY 7thgen. IT WAS WRONG!!
went back and fixed it and everthing was fine
It shouldnt be a problem with not enough fuel the injectors are a good size, and they are currently the only fuel upgrade I have. I am considering putting in a fuel return and a FPR next week. The problems I think might have to do with the tranny(auto) when you gun it it bogs but if you let it go through the gears everything goes runs smooth. As far as the afc install I used the wiring diagram that I found on this forum. The wierdest thing is sometimes when I turn the ac on the car shuts off or doesnt boost as well.
7thgen Power Maker
Originally Posted by ImportRacer2123
I got smoked last night by my buddys EP
I Defenitly need to get my VAFC II dyno tuned. I bog down right as VTEC kicks that was at 7psi too.
I Defenitly need to get my VAFC II dyno tuned. I bog down right as VTEC kicks that was at 7psi too.damn what are his mods?
Rogelio Rey
May 24, 2015 08:30 PM
Supramk3
May 8, 2015 11:16 AM
