Horn wiring short blowing fuses
Old Aug 21, 2004
Ice_Man's Avatar
Ice_Man is an unknown quantity at this point
Hi, this is my first post, thanks for bearing with me. I recently bought my first Civic, a 2001 EX 4-dr, and I've discovered that it has a problem with the horn wiring.
The horn was apparently cut and removed some time in the vehicle's past and the wires were not taken care of well enough because every time the horn is triggered, it blows a fuse. It's the fuse that is also for the tail lights, so every time it blows (which is every time I lock the car), I can't shift out of park. Obviously this is getting annoying.
I've got 3 years of an Electrical Engineering degree under my belt, so I'm fairly confident I can fix this, but my question is, where the heck are the wires for the horn?
Old Aug 21, 2004
MegaHurtz's Avatar
Can you not trace them back from the horn to the fusebox (under the dash)?
Old Aug 21, 2004
doubledeuce2k2's Avatar
the horn is located inside the front bumper, on the driver side. you will have to remove the bumper to get to it. it's bolted onto the frame of the car itself, it's black and about 3 inches in diameter. maybe the wires are just shorted. best of luck, and post some more!
Old Aug 21, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
you should be able to find a slice or something in the wire if you trace it
Old Aug 21, 2004
Ice_Man's Avatar
Alright, thanks a lot. I'll work on getting that bumper off tomorrow. I assume I'm looking for an orange wire as per the Vehicle Wiring Database, though it's probably wrapped.
Also picked up most of the parts for my sound system today. I have to say I really like this car so far, and these forums just rock.
Old Aug 21, 2004
catalin's Avatar
catalin is an unknown quantity at this point
Just wondering what does the horn fuse have to do with not shifting out of park???
Old Aug 22, 2004
fonto's Avatar
The LA Clipper
woah, a new Iceman??
Old Aug 22, 2004
Ice_Man's Avatar
Did I unintentionally commandeer somebody's name?
Old Aug 22, 2004
Ice_Man's Avatar
The horn and brake lights seem to be routed through the same fuse - if one shorts out, the fuse blows and both are disabled. If that happens, the brake lights won't activate when you push the brake pedal, and you won't be able to shift from park.
Old Aug 22, 2004
catalin's Avatar
I understand the concept but this is pretty silly. What if you're in the middle of nowhere and you need to drive to get a new fuse?? This actually happens ini your car?
Old Aug 22, 2004
MegaHurtz's Avatar
In the meantime you can unlock your shifter so that you should be able to get it out of park
Old Aug 22, 2004
Ice_Man's Avatar
Does that involve the little removable plastic piece near the shifter?
Old Aug 23, 2004
bumper isn't too tough to take off. there are a couple pop bolts in the wheel wells (i think maybe one screw), 4 pop bolts on the grill that are easily accessed under the hood (grill=that piece with the "H" on it), and then under neath the car there are about 6 pop bolts, i think 2 screws as well. take out all you can find, tug gently, and you should be good. make SURE to put a blanket on the ground or something though, you do NOT want to scratch up that nice bumper. this is the most crucial of all steps. breaking pop bolts or having extras will happen, but scratching a bumper is an expensive chore to fix.
mrohitredd
May 30, 2015 06:51 PM
davidezerron
May 30, 2015 02:45 PM
Ma213802
May 18, 2015 07:01 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
