Remote Start with 5spd, Tach wire?
Old Aug 23, 2004
coolmike2's Avatar
coolmike2 is an unknown quantity at this point
Hey guys that have installed remote start on a 5spd where did you tap into the tach wire? On the diagram it shows blue wire by battery which I see but its not plugged into anything. Multimeter goes up when car is started but still a weak voltage. So Im not sure.
Old Aug 23, 2004
MegaHurtz's Avatar
If it is easy enough, check your gauge cluster in your dash to see if you can easily distinguish that wire.
According to the DIY, there is a wire for the tach by the battery and according to how I red it, it is green with blue that needs to be exposed
Check the DIY here
http://www.7thgencivic.com/forums/sh...d.php?t=155253
and this one here
http://www.7thgencivic.com/forums/sh...d.php?t=153833
To see if you can get any useful information from there
Civic2002lx
Oct 7, 2015 09:17 AM
MamaBear2015
May 3, 2015 02:17 PM
DaveyD
Mar 28, 2003 12:28 AM
black2k1vtec
Dec 6, 2001 09:49 PM
loquito
Nov 12, 2001 07:24 PM
