ANyone ever stick your intake in the freezer for a few hours??
Old Aug 14, 2004
redvtec04's Avatar
VTEC MASTER
redvtec04 should not be trustedredvtec04 should not be trusted
Metal of course.
Read some where that someone did that and ran the car and didnt notice any appreciable gains. So I guess it's true, cooler outside air travels too fast to be heated by the metal intake pipe and too fast to be cooled by the colder pipe.
Old Aug 14, 2004
xtreme26's Avatar
xtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura about
yea, i wouldnt do it tho
Old Aug 14, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
your intake would pick up moisture, then send it into the motor.
it would only b effective for a couple min, our under hoods get REAL hott!!!
Old Aug 14, 2004
xtreme26's Avatar
yea consendation(sp?) would take affect, i think
Old Aug 14, 2004
cambo's Avatar
I wish I was asian
unless you can install an intake within 2-3 minutes, i bet that pipe heated up to ambient temperature.
Old Aug 14, 2004
jahernandez's Avatar
jahernandez is an unknown quantity at this point
Wow...I can't believe I actually read the whole post...
Old Aug 14, 2004
civic01vtec's Avatar
bwahahahahaha ...........pwn3d by a n00b
Yeah, idk why anyone would even think of trying that.
Old Aug 14, 2004
VP Stylee's Avatar
VP Stylee is an unknown quantity at this point
http://www.01designsystem.com/diis_home.html
Old Aug 14, 2004
streetglower's Avatar
Originally Posted by redvtec04
Metal of course.
Well duh, by the time your engine heats up, the pipe will be back to being extremely hot again. What people do to try and get a few extra HP. What, do they think that the intake will be ice cold from that point after. What idiots.
Old Aug 14, 2004
Civryder02's Avatar
Civryder02 is an unknown quantity at this point
waste of my time to read this topic !
Old Aug 14, 2004
some company makes a cryo intake with dry ice box for race days, but again the condensation comes to mind.
Old Aug 14, 2004
VP Stylee's Avatar
also the ice only lasts 10 minutes
Old Aug 14, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Wow Soooo Cool hahaha
Old Aug 14, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
well...i was gonna post the dyno but i thought i just tell u.. we were gonna do the same thing down at dynotune but didnt have time so we did it at the shop anywayz but the dyno was in use the whole day...but when we pulled it from the freezer we insulted it in pipe insulation to keep it cool so we can run tests... air temp into intake was at the throllte body was 54degrees and exterior temp was at 98degrees.. it only took 15 minutes before intake came back up to room temp.. one of these days when we are bored again we will try to get a dyno to see the results.. as for moisture.. its like it doesnt exist here in the desert.. u put a cold glass of water out on the table and it will not condense
Old Aug 15, 2004
Got Boost???'s Avatar
an old trick racers used to use back in the day was to inject a small amount of water into the cylinder to increase compression, it only takes a small small amount in a cylinder to increase compression.
Anyone that tried this and got noticable performance increases is most likely experiencing an effect similar to wat was described above. The moisture released is at a slow enough pace to not harm anything, but fast enough to raise compression for a minute or two.
Old Aug 15, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
wow ... stick a metal intake pipe in the freezer? ... I would think that if u stuck it in long enough, little icicles would build up and you maybe hydrolock your motor
juror
Suspension DIY
Jul 30, 2019 03:28 AM
carid
Nov 7, 2015 01:46 AM
cukaracha
Aug 10, 2015 08:01 AM
Farticle69
Aug 6, 2015 08:02 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
