noise help and new head unit pic *EVEN MORE PICS NOW!*
Rockford 8250....basically the Denon unit.
im chasing down a noise problem so i swapped head units. it doesnt fit in my custom dash cut out thats why its bare. my buddy had this one laying around so im gonna use it. good news is the deck is sweet, bad news is the noise is still there, engine noise from the front left that gets louder when AC is on.
here is what i have tried
3 head units (rockford RFX9320, Kenwood 911, and the 8250)
different RCA's
3 amps (X1.800.4, mtx 4300x, another X1.800.4)
two ground points for amp and head unit
new battery ground
up next is a small wire from battery to amp, and battery to headunit ground point...any other suggestions
Wild! I get engine noise on the right (front, but I only have two speakers amped). I still haven't fixed it. I grounded and regrounded and sanded and resanded, but to no avail. I reversed my RCAs, and the sound switched to the left side, so I know it has something to do with my RCAs (and not an exposed speaker cable or something). If you figure out what is causing your noise, let us know...
I would suggest reversing your RCAs to make sure it isn't a speaker wire that is touching the body of the car or something. Also, there is a way to bypass the remote (I think just bridge the power and remote terminals? Look that up...). You can try disconnecting the remote and then testing without the remote (esp. if you are running the remote on the side of the RCAs). I have read a few cases of this solving noise problems, much to others' surprise. This was going to be my next test when I had some time.
By the way, what kind of engine noise do you get? I get a small bit of alternator whine, but also some static.
all cabin speakers amped
ok..heres an update..got a long *** wire
grounded head unit to battery
amp to battery
battery to block
going back to to try:
head unit to amp
run RCA over interior to each input of amp
god damned **********ing noise i wanna light the car on fire.
amp to battery
battery to block
head unit to amp
The LA Clipper
I had noise problems forever...all signs always pointed to something behind the HU...after I found just the right place for the wires behind the HU the noise went away.
unit is grounded to the frame of the dash right now. maybe i shoulda just bought cheap crap..it sucks putting htis much work into a system ,gutted the car for sound deading, then wire, then saving for top end gear, then putting it all in and dealing with this crap...
heres more pics...this is my setup behind the radio.....also a pic with crap drawn in but the power constant and switched are reversed in the lableing...sue me its late....i installed a barrier strip cause i have been thru so many head units, plus i have a guage, and my Omnfi unit to hook up back there...the noise was there before the strip and with only the head unit hooked up. it makes the noise with the head unit out of the dash and the RCAs in my hand...so its not them touching the metal frame or interfering with the barrier strip.
update....
i dont get it. its still there with no signal.....i would say its the amp at this point but this is the third amp that has had this noise.....it seems most pronounced from the front right....is it possible that crossover is the source of the noise??
4 banger
Jun 5, 2015 01:44 AM
PimpBot5000
Nov 26, 2001 07:15 PM
