neon under seat wiring question
Old Aug 7, 2004
slvrcivic's Avatar
slvrcivic will become famous soon enoughslvrcivic will become famous soon enough
Question neon under seat wiring question
I have a set of neons that I thought I might install under my front seats, or under my footwells.
My question is this.
Is there a way to wire them to come on with my headlights? I have a toggle switch to hook them up, which I can wire easily.
But I wasn't sure if it would be possible to wire it into my headlights somehow. So when I would flip my headlights it would turn the neons on automaticaly. Also I would be able to flip them off with the toggle if I didn't want them on with my headlights.
I don't know where I would have to tap into the wires, or even how I would make that possible. If it would require me to fish wires through the firewall again I think I'll pass.
I can just flip the toggle. Anyone done this? Or something similar?
I've wired them to just a toggle before. No biggie.
Let me know what wires would make this possible if anyone knows.
Old Aug 7, 2004
I know how to wire them to turn on with the parking lights, but you're gonna have to run a wire to the engine bay.
Old Aug 7, 2004
slvrcivic's Avatar
do you basically have to tap into the wires coming off the back of the bulbs....headlights?
Old Aug 8, 2004
MegaHurtz's Avatar
I would highly suggest saving yourself some trouble and using either manual switches or switched power
You can do it with a relay I am sure. I am not sure how, but I know it can be done. You would just tap into the headlight switch somewhere in the interior, probably under the dash somewhere, run it to a relay and hook it up so it turns the neons on and off as you wish.
Blazz
May 25, 2015 10:56 PM
DeFiaNT
Dec 3, 2001 07:11 AM
NukeSilo
Nov 20, 2001 05:17 PM
viper775
Nov 15, 2001 10:54 PM
