DIY: Blacking Out 04 Headlight's
Old Aug 7, 2004
ImPulse's Avatar
The term, "Blacking" out headlights basically means, Painting the headlight housing, NOT Reflectors.
Materials Used:
Tape (If styrofoam peice falls off/Tape it into place)
Philips & Flat head Screw Driver
10mm wrench & extension
krylon fusion for plastic - Hyper Black
Krylon acrylic crystal clear - Hyper Clear Coat
ACE hardware heat resistant paint - Hyper Black
GE Silicone II Household Glue (clear)
The 04 body style is exactly like the 01-03 civics... You can use the DIY from the DIY page... Or by just clicking this link.
http://www.7thgencivic.com/forums/sh...d.php?t=155290
Warning: For a saftey concerns, I suggest leaving the styrofoam peice on... If honda put it there, then obviously it serves a purpose.
Basically follow the directions from Step 1 - Step 9
From step 9, you should have just removed the plastic cover of the headlight.
Now, While looking at the headlight with the reflector/housing, You will notice a screw holding the housing onto the rest of the light. Unscrew it, and place the screw somewhere (somewhere were u wont lose it).
Then you can slide the housing out.
You will have something like this,
(but, chrome colored) sorry didnt take a picture cause I was busy doing the DIY
From there, Take it into a WELL VENTILATED area, and spray the housing with plastic spray. Wait 10 minutes for it to dry, then spray over it with the high temp paint. I suggest using the plastic spray only one time (so that the paint will stick to the chrome finish, then add 2-3 layers of the high temp paint). Just spray enough so that the headlight is black . You do not want it to be dripping paint! I will only take longer to dry and will leave marks.
Next, as suggested by the high temp paint, you may place the housing in the oven so that it can fully cure. Oven set @ 225 Degrees for 3-4 Minutes. (wait for the paint to dry a lil (10 minutes before placing into oven)
After 3-4 minutes remove the housing from the oven and let it sit outside for 10 minutes.
Next, you are ready to attach everything back! Get the cover and housing and attach them backtogether and put the screw back on
What I suggest to use...
Now set the oven to 320 degrees (wait for it to reach that temperature) and turn it off.
Bring the bottom part of the headlight towards the oven (the part where the bulbs attached too). Take the silicone, squeeze the tube and place the silicone into the crevise that the puddy is in (this will help 110% seal the headlights and help precent any foggage) and put that into the oven for 6 minutes.
Take it out and you will notice that the puddy/silicone has melted, or very warm/moveable. Take the cover/housing and attach it to the bottom and put the two peices together, and make sure the clips, clip in.
Take the silicone and put a layer around the SEAL of the headlight, wait 10 minutes for it to dry and do it again (this will insure that water will NOT get in).
repeat the other headlight/done
If you have any questions please PM me, or Sent me an IM > EuR0MX
Old Aug 7, 2004
chrisleecool's Avatar
very simple..haha
good job
Old Aug 7, 2004
ImPulse's Avatar
Yea, Simple is always the best =] lol
Didnt take too many pictures cause I was telling someone to do something and had to watch in case of a mistake
Old Aug 7, 2004
Mr.Modify's Avatar
yea sounds simple enough....good job.
Old Aug 7, 2004
xtreme26's Avatar
xtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura about
dam good job, i wana do this to my bros civic but afraid im gona mess somthing up :S
Old Aug 7, 2004
ImPulse's Avatar
only part that you can really mess up is the painting part... Just try not to use a lot of paint, and just be patient.
Old Aug 7, 2004
abmerop18's Avatar
Jam out with your clam out.
nice DIY
Old Aug 7, 2004
Mr.Modify's Avatar
Im gonna try this when i have time....im always at work and what not....but it's not gonna be easy anytime soon cause schools finna start
Old Aug 7, 2004
ImPulse's Avatar
Honestly will take you like 4-5 hours if you dont know what you are doing and if you have all the supplies before you start. If you have cleared headlights before maybe like 2-3 hours.
Just do everything the right way... Read the instructions to each product and follow. Its a very time consuming DIY.
Old Aug 12, 2004
ImPulse's Avatar
Those wondering about the clear coat...
Once the black or w/e color paint you are using to paint the housing is dry, you can apply the clear coat.
Dont apply the clear coat when the paint is wet.
Old Sep 27, 2004
Ledbelly's Avatar
Im the man in the box
thanks guys for the help ( akia, cris , jp ) i love it
thanks for the diy too impulse
Old Oct 1, 2004
cubanmike26's Avatar
Very nice DIY Impulse. Thanks!!
Old Dec 26, 2004
03CivicNyte's Avatar
03CivicNyte is an unknown quantity at this point
Nice..Sound easy I'll try it this weekend
Old Dec 27, 2004
ArthurBrazil's Avatar
ArthurBrazil will become famous soon enoughArthurBrazil will become famous soon enough
gj i wanna try it on my 4g
Old Mar 1, 2005
paradoxblue's Avatar
k need to fix the pics or remove the thread.. i wanna do this but without pics im lost :'(
Old Apr 4, 2005
I tried this DIY, but honestly I was having I really hard time trying to separate the headlamp...seems like the silicone on mine was really hard...any ideas on how to soften it?? Thanks...
Old Apr 4, 2005
Akutenshi's Avatar
The Rizing Sun
preheat ur oven to 250...... stick em in here 1 at a time for 5-10 mins......
itll be as gooey as hell once u take it out.
Old Apr 4, 2005
Oh, that'll help...thanks.
Old Apr 17, 2005
benya7thmix's Avatar
benya7thmix is an unknown quantity at this point
ok 3 hours later and i am convinced that 04 sedan's headlights DO NOT seperate.....
grrrrrrrrrrrr.... and if so, what part gets blacked out.... i desperately need pics
--BENYA
Old Apr 18, 2005
Akutenshi's Avatar
The Rizing Sun
ur doing something wrong. mine came apart easily after like 5-10 minutes of being in the oven
heres what gets painted
those are from a 6thgen civic SI's headlights. but u get the idea. its basically the piece that comes apart from the headlight in between the headlight and the clear cover. its right in the middle being held in by a screw. u cant miss it. just look at pictures of people's 04 05 headlights that have been blacked out before n u can tell which part it is.
Old Apr 18, 2005
putting them in the oven seperates the headlights? i thought the oven step was for drying the paint only?
Old Apr 18, 2005
slowvr4's Avatar
slowvr4 is an unknown quantity at this point
I believe the heat loosens up the adhesive that's holding them together..
Old Apr 18, 2005
Some dude I know separated his with a heat gun, you can also try that if you think the lights will get messed up...
Old Apr 18, 2005
oh my god, i can't believe the oven worked...... for some reason putting my head lights in the oven seemed so wrong, but now it seems so right...
Old Apr 18, 2005
Akutenshi's Avatar
The Rizing Sun
hah told ya
Old Apr 18, 2005
i still can't believe the oven worked..... the rest of the assembly was pretty easy, keeping the headlight clean while doing it was tough, but all and all it was easy.
and they look great!!
wingsfan19
Oct 1, 2015 03:45 AM
MamaBear2015
49
Sep 29, 2015 01:12 PM
MamaBear2015
Sep 4, 2015 09:04 PM
jpat21
Sep 3, 2015 11:32 PM
mac25
Aug 21, 2015 11:14 PM
