do you raise your car in the winter?
Old Aug 1, 2004
Premium Plus's Avatar
Ninja Crew
Premium Plus is just really nicePremium Plus is just really nicePremium Plus is just really nicePremium Plus is just really nicePremium Plus is just really nice
should this be done?
im prolly lowering my ride with neuspeed sport springs...so im lookin at about a 1.75" drop. can i keep that throughout the winter? or should i put my stock springs back on for the snow season?
what does everyone else with lowered rides do?
Old Aug 1, 2004
dubz01si's Avatar
dubz01si is an unknown quantity at this point
i used to drive in the snow but i donno its best ya dont bother get a beater
Old Aug 1, 2004
takumi's Avatar
takumi is on a distinguished road
Get coilovers, you can adjust the height whenever you want.
Old Aug 1, 2004
smokedcivic's Avatar
"SLIPSTREAM R"
smokedcivic has a little shameless behaviour in the past
i have neuspeed sport springs and i have gone through 2 winters with them on now problems... but i would suggest that you do get a winter beater due to the fact the springs will go faster from rust build up..
Old Aug 1, 2004
iamfob's Avatar
iamfob is an unknown quantity at this point
same as what smokedcivic said
i have a front lip too, i plow a bit but it's not that bad and of course if the road condition is too bad then dont drive the car if possible
Old Aug 1, 2004
Ninja Crew
well, im thinkin of goin through one winter with my car lowered, and getting a set of koni yellows in the spring, so next winter i can raise it up. but what im gettin from this thread is one winter, should be okay
Old Aug 1, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I had my H&R's on for one winter, did some plowing due to the front lip. Cities of Mississauga, Toronto, and Hamilton owe me money now for the plowing services. But overall wasn't a bad experience or anything. This year since I have Hayames I'm raising it up to stock for the snow.
Old Aug 1, 2004
jer2k's Avatar
jer2k is an unknown quantity at this point
I drove with H&R for two winters with a full Kaminari Kit. I absolutely killed the paint on the front and sides skirts. The plan is to remove the skirts for the winter this year. I will still be dropped but there will be no problem without the kit on.
So in summary, if you dont have a kit you will be fine IMO
JD
Old Aug 1, 2004
vvii's Avatar
vvii is an unknown quantity at this point
i use neuspeed race + koni , no problem at all, and I don't think you want to raise you can just for the winter, it will be too much work
Old Aug 2, 2004
rokenrolcivic's Avatar
rokenrolcivic has a spectacular aura aboutrokenrolcivic has a spectacular aura about
yeah just get a beater
Old Aug 2, 2004
1llmatic's Avatar
1llmatic will become famous soon enough
again...i'm on neuspeed race springs...there's no need to raise your car...the 7thgen is already high as it is...even lowered
Old Aug 2, 2004
Falcon's Avatar
Falcon is an unknown quantity at this point
im dropped about 2.5 inchs
in the summer i use oversized wheels.. and the diameter is about an inch more than stock... so when i put my stock rims back on in the winter, i actually sit lower than in the summer
so, if you're asking me if i raise my car for the winter.. my answer is no, i lower it by about 1/2 an inch
Old Aug 2, 2004
nogi1's Avatar
nogi1 is an unknown quantity at this point
get a beater honda's rot out
Old Aug 5, 2004
Shu's Avatar
Shu
Shu is an unknown quantity at this point
Koni Yellows DO NOT let you adjust your ride height, only stiffness.
I've been on Neuspeed Sports thru a winter as well, no problems...
Old Aug 5, 2004
Booohahaha's Avatar
BAD MON
winter's are rough on coilovers.....>,<
well at least wif mine.. im just too lazy to raise it and lower it..
Old Aug 5, 2004
AznSaint's Avatar
AznSaint is an unknown quantity at this point
if you raise it each winter that comes along.. you're most likely going to have to get an alignment..... unless you dont mind driving with a tilted steering wheel.
i've been through this past winter with like a 2" drop... i have like a one finger gap with my winter tires on... half a gap in the rear. i just usually watch where im driving.. but when i plow.. i usually dont have a choice.
i have winters on usuallly... so not much of a problem b/c i got grib while moving...
sharp66
31
Jun 12, 2022 08:45 AM
ChristinaVHH
May 10, 2015 03:51 PM
bsmiley
Apr 27, 2015 01:27 PM
SneakerPimp
Bolt-on Engine Performance
Nov 4, 2001 01:12 PM
sonsonzai
Nov 4, 2001 12:52 PM
