you want brighter headlights?
Old Jul 31, 2004
Then this may be for you. Increase the output of your stock halogen by up to 200% by turning a ****. Great alternative to getting HID. It's a bit pricey, but remember that HID is 300% brighter than stock. For less than 1/2 the price of HID, this thing boosts power 200%!
http://store.racinglab.com/geesyheoubo.html
Old Jul 31, 2004
NoLeadEmSoMuch's Avatar
NoLeadEmSoMuch will become famous soon enoughNoLeadEmSoMuch will become famous soon enough
does it eat up the 12v outlet?
Old Aug 1, 2004
Akutenshi's Avatar
The Rizing Sun
hm.. gearbox, if u didnt have hids. would u rather save up for em, or buy that kit ur talking about?
Old Aug 1, 2004
Actually, I probably would have gone with the kit. The increase is almost as bright as HID, but less than $200 instead of almost $400 I paid for the hid. And it should make all aftermarket bulbs brighter, which is the problem I had with my old cool blues.
I think this has to be wired to the headlight harness or something. It's not as simple as plugging to the 12v socket.
Old Aug 1, 2004
Akutenshi's Avatar
The Rizing Sun
it comes with instructions tho right? or is this one of those things that amatures shouldnt be trying to instal by themselves n take it to a shop instead. <<not all of us are as l337 as u
Old Aug 1, 2004
I sure hope so. I'm only guessing, but I think this involves a wire harness upgrade for the existing headlights (by way of a larger gauge power wire) to support higher voltage. Then by turning up the ****, more voltage is sent to the bulbs. I think it's like a full system to run higher wattage to the bulbs. In doing so, the bulb life may be gradually reduced (since they are designed to be run at stock wattage 55/60). It also says they switch to low mode when the car is stopped. So that's good for saving current when the alternator isn't working hard.
Old Aug 3, 2004
dru106's Avatar
ThE CoRRupToR
Im not sure but i think YS had those and he had problems wit it blowin his bulbs up. It would work fine until a couple of months. He said that this one time the bulb shattered in pieces inside the headlight.... I would just save up $$ for hids better
Old Aug 10, 2004
dannn's Avatar
unique conformist
dannn will become famous soon enough
couldnt you just buy better bulbs that support the increase in power?
Old Aug 10, 2004
Yeah, you could just buy higher wattage bulbs and upgrade the harness. But they still won't last as long as regular bulbs.
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
