Custom eq mount..opinions needed
Old Jul 31, 2004
I have an eq that's gonna try and go where the sig lighter plug is and spacers. Has anyone done this, because I'm having trouble making it work. It's for an 02 civic btw.
Okay, it's made and turned out okay, except with a space in the top part that's visible when looking down. My main concern is the way the eq will look when mounted. I'm worried about the light being too bright compared to my other blue dash leds. Now is there a way to turn off the backlight for the eq if this is the case? If not, I'm thinking of hiding it underneath that sliding pocket by the e-brake. That way I can keep it hidden and open the slot to adjust it. What do you guys think? I know I'm being picky.
Old Jul 31, 2004
Cmon people. Give me some ideas of how to make a trim plate at least or rubber molding around the edges.
Old Aug 1, 2004
LudlamTheory's Avatar
i boogie for the raindrops
use the same diy i put up for the radio relocation down there, its teh same concept, and if you screw up the cig lighter panel, it only costs 14 dollars for a new one
Old Aug 1, 2004
I'll look for that and also try to get a pic up of what I did so far. Thanks.
I found it, but I'm not doing any custom work like that. I want to make it as clean as possible. I have two ideas, but one requires a faceplate trim piece to work. The other way is only having part of the eq visible. I'll describe more later.
Old Aug 2, 2004
vivid_BLUE's Avatar
make it a habit
vivid_BLUE will become famous soon enough
What DIY? i tried to search but couldn't find
Old Aug 2, 2004
Well I just cut a hole and it looks good, however, I'm having another dilemma of how the eq lights will look at night. They look really bright in pics compared to my other dash lights. Hope it isn't gonna look stupid cause I already have tons of stuff lit up. We'll see. I'll post pics later.
Old Aug 5, 2004
Updated with pics.
Old Aug 5, 2004
alex053's Avatar
what EQ are you using and what movies did you rent?
Old Aug 5, 2004
It's an arcaudio keq5 1/2 din size. So I would need to fill the spaces in with abs plastic. Movies are A.I. and power rangers woo!
Old Aug 5, 2004
KnocturnalEM2's Avatar
I am your Mom's Hero!!
I think that eq is gonna look awesome there Stephen...UPS should be there wednesday...
Old Aug 5, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
For a solution to the gap thing, you could always fiberglass/bondo around it to clean it up. Then paint with black, crackle finish interior paint. It matches up pretty good with our interior color.
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
Myredjonda
Apr 14, 2015 07:00 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
