Yellow top vs stock
Old Aug 2, 2004
MegaHurtz's Avatar
Yellow top vs stock
Will I really gain that much more reserve capacity if I swap my stock battery for a group 51 yellow top?
My car has been sitting a decent amount lately, and I have an alarm LED scanner and TV tuner antenna that are always on even when the car is off. If I don't drive my car for a couple of days, my battery dies.
If I switch to a group 51 yellow top, will it make that much of a difference? If the physical size is the same, how much more capacity could there really be?
Old Aug 2, 2004
It's pretty similar to stock, only draining it won't damage the battery. That's why yellow top is recommended if you bump a stereo with the car off. cca is a bit higher than stock as well.
Old Aug 2, 2004
MegaHurtz's Avatar
Do you have any idea as to waht the specs of the stock group 51 are, or if the reserve capacity is much higher with the yellow top?
When it drains, it doesn't drain COMPLETELY, just enough to not start the car. Is that as damaging as being totally draiend or not as bad?
Old Aug 5, 2004
The yellowtop has the same reserve as stock I think, with a bit more cca. It's very bad for the stock battery to drain below starting capacity. Over time, the battery will never be able to sustain a full charge. The yellowtop doesn't get damaged nearly as much from draining it. It also charges faster than stock.
Old Aug 5, 2004
MegaHurtz's Avatar
maybe I will look into it then
thanx for the bump I forgot about this thread
Old Aug 5, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
you would be better off modding your battery tray and putting in a truck or SUV battery....group 60 or 61 I think. They have like 1000 CCA's and more reserve capacity than yellow tops.
Old Aug 5, 2004
Yeah but cca is only for starting the car. Who cares if there's more, since it still starts. People with yellowtops have let their vehicle sit for months and have it start up just fine.
Old Aug 5, 2004
MegaHurtz's Avatar
How easy is the battery tray mod to do?
Old Aug 5, 2004
Well you could just take it out. I needed room for my HID stuff, so out it came. You'll have to take off the top cover too if you get a bigger battery.
Old Aug 5, 2004
MegaHurtz's Avatar
I don't care about the cover
If I just take the battery tray out, what will the new battery sit on?
Will the factory air cleaner clear a larger battery?
Old Aug 5, 2004
Mystic3030's Avatar
You have to play with it, built something to hold the battery in. Pipe strapping works. Ludlam is running a battery with I think 3x the reserve capacity of a yellow top.
Old Aug 5, 2004
doubledeuce2k2's Avatar
i think i rmember group 25 batteries being an almost identical size, but with more storage. 34/78 are also doable w/out much effort. most places where you'd buy batteries will have tiedowns too
Old Aug 5, 2004
MegaHurtz's Avatar
What kind of battery and how big (physically)?
I can just use a tie down can I not?
What will the battery sit on if I remove the tray, is it possible for it still to sit flat quite easily?
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
Nigel Evans
Jun 10, 2015 06:35 PM
Ocenica
May 30, 2015 06:53 PM
supercivic01
South
Nov 30, 2001 11:27 AM
