Problem with indiglo needles.
I change my gauge to indiglo, but when I finished the needles don't run. I verify again and nothing is touching the needles or getting stuck. I need to calibrate the needles. Pls let me know. Registered!!
give it a couple of days to see if they start moving again... some members such as me had the problem but after a couple of days my gauges were working fine.
To have it calibrated you would prolly have to go to the dealer
Injen
Injen
I got a civic coupe 98, i was installing a new fusible for the back lights, and when i start the engine all the lights went off, i chequed the fusibles but all of them seens to be oq....what can i do? i don't have the cover of the fusibles, got lost....i don't know where is the problem?
Crack kills... But then again... So do I...
Ok... Starting off stupid question... Did you tape the gauges??? You need to make sure that you have double side taped the gauges to the original OEM cluster or else the gauges are going to always be rubbing up against the needle... Being out in the desert during the sumer was murder on the tape and I had to constantly change it. And I found it wasn't really worth the previous install to keep my indiglo gauges. Still looking for a better set though, but until then, Whack *** orange dials 4 me....
ibtl this has been a problem since the beginning of people putting indiglos over their stock guages. Do a search next time because people use to ask about this all the time. Also if you follow the diy correctly from the diy section you will have not had any problems
Once again IBTL, www.search.com
We were all nOObs at one point or another... Ease up... C'mon dude has 3 posts... That prolly means, he not familiar with the site yet... Ready... Inhale.... Hold.... Exhale... People are way to quick to jump on people here...
^^^cause it is fun. The less people that come back after getting jumped about not search the less people I have to telling to searching or the less times I have to type out ibtl or ibtm.
Oy.... Go right ahead and give your tough love... It's all good, just please be productive at the same time... If you give info, please feel free to bash away... It is fun to make them feel stupid, but then educate them in their wrongs....
No thanks I prefer to leave it as it is. If they want answers they can use the help I gave them by actually doing the search.
OK... ce la vi.... Please continue what it is you are doing and enjoy every minute of it... A hui hoa malama pono...
Aznnp77
Jan 6, 2002 08:41 PM
