Diy: Visual Headlight Aiming Procedure
Old Jul 23, 2004
ImPulse's Avatar
For all of you that get any kind of aftermarket headlights/projectors... This is a MUST.
Heres a link that will explain EVERYTHING to you...
http://www.autooptiks.com/aiming.html
If you have any questions, please PM me. I did this like 8 times
Old Jul 23, 2004
Someone did a diy here using pics of the car and adjusters. It's way too much work imo. Just drive up to a glass store window at night and see how your reflection looks. If they're pretty much low and even, and people don't ever flash you, that's good enough
Old Jul 23, 2004
ImPulse's Avatar
well, if u want things done right... plus for people with cough... a retrofit... cough, and want people to see lots of color
Old Jul 25, 2004
doubledeuce2k2's Avatar
thanks for this, i should probably do this til i buy some projectors. i got highbeamed for the first time buy a dumb 'lude tonight... but my 25% tint made me really not care about him
Old Jul 29, 2004
MIAMIVTEC's Avatar
MIAMIVTEC is an unknown quantity at this point
how do u aim tyc projectors? im having a hard time with mine. my drivers side tyc is lazy eyed.
Old Jul 29, 2004
FALKEN's Avatar
Civicforums Junkie
Originally Posted by MIAMIVTEC
how do you aim TYC projectors? im having a hard time with mine.
http://www.7thgencivic.com/forums/sh...ad.php?t=91984
Old Aug 3, 2004
JX6's Avatar
JX6
Redline Adrenaline VP
JX6 has a spectacular aura aboutJX6 has a spectacular aura about
I've been aiming my heads for the last 2 days and for some reason I got the beams even on low even my left light is brighter,but when i cut on my highs the left beam is low and the right beam aims like 3 feet higher.anyone know why?...ImPulse
Old Aug 3, 2004
ImPulse's Avatar
are you using projectors? or oem housing?
IF its projectors... You need to adjust the high and low beam... There are different screws to turn...
IF its oem, Then, I dont know what could be wrong? are you sure its leveled correctly?
Old Aug 3, 2004
JX6's Avatar
JX6
Their OEM.
I don't know whats the deal.
Old Aug 3, 2004
ImPulse's Avatar
if u have any other h4 bulbs around swap them and see if anything changes.... Thats odd o_O Maybe the filament is messed up?
Old Oct 31, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
I definitly need to do this, ever since i put my headlights back on after clearing them i swear my headlights arent pointed correctly. THanks for the info
Old Nov 6, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
holy crap.. i just put my new headlights in.. good friggin lord they are off.. my car now looks like that lazyeyed can that is always outside
Old Nov 6, 2004
LiKEaFeRiO's Avatar
http://www.7thgencivic.com/forums/sh...adjustment+56k
I made the DIY and here is the link.
If you have a coupe, your stock housings can only be adjusted up and down.
If you have a sedan, your stock housings can be adjusted up/down and left/right.
Most if not all aftermarket OEM replicas (gunmetal,JDM black,etc...) are model after the sedans and have both adjustments.
Old Jan 6, 2005
DjReaction's Avatar
DjReaction is an unknown quantity at this point
I have the Black Housing HALO lights and I cant find where the part is that adjusts them! my lights look STUPID cuz one beam is SO high and the other is so low, anyone have these exact lights and know wwhere the adjuster is located?
Old Apr 20, 2005
GreatWhite02's Avatar
4 cyllinders are good but 5 is better!
GreatWhite02 is an unknown quantity at this point
link doesnt work!
Old May 2, 2005
matt_s's Avatar
Super JDM Member
matt_s is an unknown quantity at this point
for the black housing projectors, there are screws for both the high and low beam. From what i remember, the screws on the low bean stick out way more, and the ones for the high beam are more screwed in.
Old Jun 6, 2005
2K2SilverCivicSiR's Avatar
2K2SilverCivicSiR is an unknown quantity at this point
there should be couple silver screws that stick out a lot.. you need to turn those....
Old Jun 25, 2005
supertikkigod's Avatar
supertikkigod is an unknown quantity at this point
Impulse... get back to me with update about my HIDS.....
shaejb15
Sep 12, 2015 01:02 AM
pfwel1977
Sep 10, 2015 02:16 PM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
