Diy: Visual Headlight Aiming Procedure
For all of you that get any kind of aftermarket headlights/projectors... This is a MUST.
Heres a link that will explain EVERYTHING to you...
http://www.autooptiks.com/aiming.html
If you have any questions, please PM me. I did this like 8 times
Someone did a diy here using pics of the car and adjusters. It's way too much work imo. Just drive up to a glass store window at night and see how your reflection looks. If they're pretty much low and even, and people don't ever flash you, that's good enough
thanks for this, i should probably do this til i buy some projectors. i got highbeamed for the first time buy a dumb 'lude tonight... but my 25% tint made me really not care about him
Civicforums Junkie
Originally Posted by MIAMIVTEC
how do you aim TYC projectors? im having a hard time with mine.
Redline Adrenaline VP
I've been aiming my heads for the last 2 days and for some reason I got the beams even on low even my left light is brighter,but when i cut on my highs the left beam is low and the right beam aims like 3 feet higher.anyone know why?...ImPulse
are you using projectors? or oem housing?
IF its projectors... You need to adjust the high and low beam... There are different screws to turn...
IF its oem, Then, I dont know what could be wrong? are you sure its leveled correctly?
holy crap.. i just put my new headlights in.. good friggin lord they are off.. my car now looks like that lazyeyed can that is always outside
http://www.7thgencivic.com/forums/sh...adjustment+56k
I made the DIY and here is the link.
If you have a coupe, your stock housings can only be adjusted up and down.
If you have a sedan, your stock housings can be adjusted up/down and left/right.
Most if not all aftermarket OEM replicas (gunmetal,JDM black,etc...) are model after the sedans and have both adjustments.
I have the Black Housing HALO lights and I cant find where the part is that adjusts them! my lights look STUPID cuz one beam is SO high and the other is so low, anyone have these exact lights and know wwhere the adjuster is located?
for the black housing projectors, there are screws for both the high and low beam. From what i remember, the screws on the low bean stick out way more, and the ones for the high beam are more screwed in.
shaejb15
Sep 12, 2015 01:02 AM
pfwel1977
Sep 10, 2015 02:16 PM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
plus for people with cough... a retrofit... cough, and want people to see lots of color
