Help D2 dissassembly
Old Jul 8, 2004
AzNmiKex215's Avatar
2k1civic.com O. G.
I need to swap out the springs of the front Sturts of my D2 coilovers. How can I secure the top mount from spinning so I can undo the bolt? I am not able to put it on the car to do it.
Is there any other way?
Old Jul 8, 2004
Vinh's Avatar
this is new to me......
Old Jul 8, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Can't you take them apart from the bottom?
Unscrew the mounting bracket, then the 3 lock nuts and off comes the spring.
Thats far easier than dicking with the camber plate and the pillowball.
Old Jul 8, 2004
2k1civic.com O. G.
Nah, the D2's only have 2 lock nuts. THe bottom end is completely welded together.
Old Jul 9, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Grab the top protruding end with a wrench of the correct size and turn the big nut with another wrench.
Old Jul 9, 2004
2k1civic.com O. G.
Yea, im guessing i need to grip the top peice with a vise grip.
Old Jul 9, 2004
Jap-Euro Fusion
Take the camber plate off first. The 4 allen screws remove it. Then you'll need to grab the big nut on top of the pillow ball, and put an allen wrench in the top of the shock piston rod. Get someone to hold the shock still or clamp it in something by the lower bracket. Don't grab the camber plate's bearing surface! Its aluminum, and the vise will crunch the edges they'll get sharp and they'll dig into the underside of the plate, and if there's munched edge stuff sticking up, it'll effect your camber later. After you get the nut off, as long as theres nothing on the underside of the pillowball holding it there, the bearing plate and pillowball should come off and the spring should come out.
This is just good theory here, I don't know for sure because my JICs disassemble from the bottom.
Old Jul 9, 2004
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
i did it last night by just 'burping' it with an impact it came right off. i tryed grabbing the top piece with one wrench and the bolt with anouther, but the top piece is not nearly strong enough for that. it kinda bends. good luck
Old Jul 9, 2004
Shlomo's Avatar
Shlomo is an unknown quantity at this point
how many people got the wrong springs w/ the D2s??
Old Aug 14, 2004
Shlomo's Avatar
are you guys leaving in you dampening adjusting **** in or taking it off. I have mine in but the hood doesn't close all the way. I don't want to leave it out because i don't want anything to get in that small hole. What are you guys doing?
Old Aug 14, 2004
CrazyCakes's Avatar
leavit out don't worry about it
Old Aug 14, 2004
Shlomo's Avatar
ok, just wanted to know what other people are doing.
Dave Brabant
Sep 12, 2015 08:39 PM
sniperscout
Interior DIY
24
Jun 6, 2011 06:08 PM
02Honda34
Feb 28, 2010 08:28 PM
2k1_Toaster
Dec 2, 2008 01:02 PM
JamesL
Mar 13, 2008 02:20 PM
