If you have problems with your door lock, ask me.
Old Jun 28, 2004
streetglower's Avatar
Arrow If you have problems with your door lock, ask me.
Well I was going to post a DIY for removing the door lock actuator, thanks to AzNmikex215, but I have no pictures and will try it later. I did this project today and if anyone needs help figuring out how to fix there problem, just let me know. This is for people who cant use there remote because it only locks/unlocks one door and they have to use there key.
Old Jun 29, 2004
JCap's Avatar
JCap is an unknown quantity at this point
was it hard/time consuming? I having this problem right now with my driver's side door.
Sometimes it will lock/unlock without problem, other times it will get half-way down to lock or half-way up to unlock.
It's starting to **** me off........
Old Jun 29, 2004
zen_master's Avatar
perfect!
actually...i got the problem with my bro's 00'SI.....i wonder if it's the same thing..
Old Jun 29, 2004
No it is not time consuming. It took me 4 hours because I was trying to get off the wrong part. If it wasnt for that, it would have took me about 30 min. or so. Well J-cap and zen master, this saturday, hopefully my new door lock assembly will come and while I am doing the install, I am going to post a DIY while doing it. If you have any other specific questions, just let me know. JCAP, BTW, what you might want to do is pull your door panel off and check and make sure all your rods are connected. It sounds like something other than the actuator. Also test the actuator to see if you have power going to it.
Old Jun 29, 2004
zen_master's Avatar
hm hm..
well, the problem with the SI is that....when he wanna lock it, the lock wiggles and then.....not closed.
Old Jun 29, 2004
Uh, it just wiggles but doesnt lock.
Old Jun 29, 2004
zen_master's Avatar
exactly....
Old Jun 29, 2004
for both of you, go outside and open your door that you are having problems with and put your ear close to the bottom right, the side where the 3 bolts are on the door and push the lock button and see if you can here your actuator?
Old Jun 30, 2004
JCap's Avatar
I'll look at it this weekend.... It'll give me something to do.... THX Street
Old Jun 30, 2004
no problem, like I said if my part arrives on saturday, I will do the install and post a DIY for it. So look around saturday evening. Otherwise I will post if it doesnt come.
Old Jul 13, 2004
hankscorpio's Avatar
hankscorpio is an unknown quantity at this point
Hey Jcap, did you ever take a look at your door or be able to figure out what was wrong with it? I have the exact same problem. Sometimes my driver door locks fine, and other times it gets stuck like half way and i need to use my key or push it. Let me know, thanks.
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
MamaBear2015
May 18, 2015 07:37 PM
maaronia
May 14, 2015 10:46 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
