Tie rod question.
Old Jun 24, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
Tie rod question.
For some reason the tie rod bolt is spinning and I can't get the nut back on. What do I have to do it keep it from spinning?
Old Jun 24, 2004
macrossranma's Avatar
macrossranma is an unknown quantity at this point
use a c clamp to hold secure the tie rod and turn bolt
Old Jun 24, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
I used a reversed c-clamp and put it between my inner fender and top of the tierod to keep heavy pressure on it. That worked fine.
Old Jun 24, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
yeah, or you could use the OEM jack.. look at my spring install DIY where I talk about the tie rod. I even have a pic of how to prevent it from spinning.
Old Jun 24, 2004
All Eyes On Z
Thanks.
Old Jun 24, 2004
abmerop18's Avatar
Jam out with your clam out.
ya i had that same problem. i just used the oem jack and it worked perfect. good luck
Old Jun 24, 2004
All Eyes On Z
How much are the c clamps?
Old Jun 24, 2004
flotsamm's Avatar
Cheap ones can be bought at Home Creepo for 10 bucks depending on size. Are you installing your Hayame V2's? Did you drill out the hole? I ask because it makes me wonder if this is why the hole is suppose to be tapered on the steering arm so that it can stop the tie rod bolt from spinning.
Old Jun 27, 2004
All Eyes On Z
I'm uninstalling Hayame V2s and will be installing B+Gs. I was trying to flip the tie rod to go under, but the hole was drilled out from the bottom as well when my friend drilled it. I was supposed to receive new front collars but there's no need for them now.
And yes, it's probably why it is moving. Because the hole was drilled out too big, the tie rod isn't even secured on the steering arm - which is resulting in some shitting handling with an even shittier alignment. It was never meant to be drilled but Hayame said so.
Old Jun 27, 2004
tfnaaf's Avatar
BLDNPSI Mod
are you trying to say that you drilled out the tie rod hole so it nolonger has a tapper, and re-installed your tie rod????????????????????????
Where do you live cause if its close to me let me know next time your driving it so i can get off the streets
Old Jun 27, 2004
All Eyes On Z
First of all, SPW told me to drill it... and the top portion was not tapered.
Second of all, I didn't drill it, someone else did. I didn't need him to drill all the way through but apparently he went against what I wanted. It's all good either way.
I'll wave if I spot you in Emeryville, CA.
Old Jun 27, 2004
civic01vtec's Avatar
i used a bar and put leverage down on it and then tightened the nut up
Tedverseti
Apr 23, 2020 01:45 PM
rovafa2002
Sep 28, 2015 06:57 PM
IronFist
Sep 25, 2015 07:13 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
