TeLLy needs alignment BAD
Old Jun 21, 2004
TeLLy's Avatar
Yes, it's an Acura EL
OK guys, got my Hayames installed (kickass), nearly killed myself on the way home (long rant in another thread soon). But my toe in is HORRIBLE. I'm
talking with my steering wheel straight the driver's front faces in quite noticably and the passenger's as well, but not as bad. I gotta get this fixed ASAP, I'm fighting the wheel even on a straight line. I really really wanna avoid any kind of highway driving, so if anyone can recommend a place that can do lowered cars (i have a body kit too) IN MISSISSAUGA please do. I know Gilman and a bunch of places out in scartown can do it, but I'm afraid of taking her out there....control really is that bad. Please help, TeLLy is sad.
Old Jun 21, 2004
nitehawk's Avatar
Hey Telly my brother lives in Sauga too and his RSX is pretty low. He just got a bunch of Suspension work done at Woodbine Acura (I think) They have a good set up their for modified cars and stuff.
Old Jun 21, 2004
TeLLy's Avatar
Kickass, that's where I bought my car. I'll check to see if they can help me out. They're a little pricier than most tho so I wanna cover all my bases too....
Old Jun 21, 2004
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
i'm gonna go check out wheel and tire zone tomorrow or give them a call for a quote. i'll let you know what i find out.
did you invert the tie rods?
i never would have thought that little turn would make the fronts toe in that much!
but i'm more of less in the same boat as you, really odd to drive with a toe-in setting. hahahahahaha
Old Jun 21, 2004
TeLLy's Avatar
Yeah I flipped the tie rods. I never thought I would have gotten THAT much toe in just from flippin the damn things! Do you find yourself fighting the wheel a lot? Seriously my driver's side is so skewed it's turned in about an inch and a half when the steering wheel is straight! And the passenger wheel, at the same time, is turned in a half inch!
Old Jun 21, 2004
Blkcivic's Avatar
is it that front or back? when i put mine in, the front was so bad that it wasted my tires in one day in the snow...... if its the front you can fix it easy because the housing have camber bolt holes...any agliment shop can do it for you
Old Jun 21, 2004
TeLLy's Avatar
It's the front. Camber I'm not worried about. Toe is killing me. It's to the point that turning is an adventure. The car wanders all over the place, and will smack into the curb in 2 seconds if I don't hang on to the wheel for dear life.
Old Jun 22, 2004
SedanBoy's Avatar
i'm in the same bolt, just not as extreme.
did you have any issues with getting the two bolts in the front to go in?
i found it to be a really snug fit.
i'm thinking the camber holes are useless now!
Old Jun 22, 2004
TeLLy's Avatar
I agree - no point with the camber holes. But I had no problem getting the two front bolts to go in - you're talking about the ones that bolt the strut to the brake assembly right?
Old Jun 22, 2004
SedanBoy's Avatar
yupyup.
i had to "encourage" them to go in.
but overall, it was jsut a very snug fit.
Old Jun 22, 2004
SedanBoy's Avatar
Well, after my alignment at Wheel and Tire Zone I have proved two things.
1) The camber holes in the front are useless.
2) I seriously need a camber kit now! I'm running close to -1.5 deg in the front and -2.5 in the rear!
But besides that, everything seems to be a lot tighter and handling much much better. No more wandering civic! Haven't had a chance to give it a good spirited run yet, but I think it'll all be good.
Old Jun 22, 2004
flip114's Avatar
flip114 is an unknown quantity at this point
I know wheel and tire zone (mississauga on eglinton) does wheel alignment even for lowered cars. Its about 100-150$ as i remember.
Old Jun 24, 2004
518's Avatar
518
518 is on a distinguished road
SedanBoy, do you have a V1? My V2 is still adjustable to correct camber but I want to run into a little aggressive set up while maintaning a maximum streetable settings so I have a -1.5 front and -1.0 rear camber. Zero toe all around and OEM spec caster settings.
Old Jun 24, 2004
SedanBoy's Avatar
I have the V2.
With both bolts in, the top hold is fixed at only one position that tightly allows the bolt to pass through.
I'm running roughly the same camber as you, -1.5 front and -1.5 rear with zero toe and in spec caster.
Old Jun 24, 2004
TeLLy's Avatar
My camber:
-0.9 FL
-1.3 FR
-1.5 RL
-2.9 RR
Crazy, yes. I don't think I'm gonna end up with a camber kit though.
Old Jun 25, 2004
Blkcivic's Avatar
hummm the alignmet shop around my house did mine and its all straight now, and costd only 60 bux....u guys should come down here and do it
Old Jun 25, 2004
TeLLy's Avatar
Well blkcivic, I'll keep that in mind next time considering I'm in Hamilton every weekend.
Old Jun 25, 2004
SedanBoy's Avatar
damn it!
i should have waited a bit longer!
i got charged an arm and a leg for alignment at wheel&tire zone
Old Jun 25, 2004
TeLLy's Avatar
Dude, all you needed to do was check your pm....s'ok, want a hug?
Old Jun 25, 2004
SedanBoy's Avatar
by the time i checked my pm, it was already 12 hours after i got the alignment. keke.
next time i gotta check my pm every 15 mins to make sure i don't get jacked again. hahahahahahaha
damn these coilovers are amazing!!!!!!!
i'm in love!!!!
Old Jun 25, 2004
dacivic's Avatar
dacivic is an unknown quantity at this point
Too bad there ain't many twisty roads in toronto to test this coilover...
Oh by the way check out the 3rd annual Mid-Atlantic Meet in my signature
Old Jun 27, 2004
infinite's Avatar
infinite is an unknown quantity at this point
wheel & tire zone is the BIGGEST rip off tire shop in ALL of ONTARIO!! Please do NOT go there unless you like paying 50% to 100% more. the guy that runs the place, i think his name is andrew (the fat guy), is a real looser. guy doesn't know how to handle customers, treats people rudely.
cukaracha
30
Jul 26, 2015 12:01 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Bounddyy
Jul 8, 2015 11:22 AM
cgavin1
Jul 7, 2015 07:10 AM
robbie374
Jul 7, 2015 02:56 AM
