Service Manual Question?
Installing the rear shocks for my d2 coilovers and wondering torque for three top nuts and bottom nut as well as the bolts that hold rear camber kit together. Any other advice would be appreciated.
Thanks
Thanks
The Standard One
*shrugs* i just go by the feel of it... pretty tight though. the bottom i remember i had to put all my weight into it to get it off so thats what i did.. the rear wasnt as hard but it was still pretty hard so i did the same...
Front nuts and bolts that hold shock assembly to brake assembly(2 on each side):
116ft lbs. (includes oem replacement bolts)
Front end links:
29ft lbs
Front bolts that hold the bracket and bushings on front sway bar:
29ft lbs
Front nut that secures tie rod to shock assembly:
32ft lbs
Front and rear shock tower nut in center (on top of shock)
33ft lbs
Front three shock tower nuts (on top of shock around center bolt)
33ft lbs
Front brake hose and wheel sensor harness bracket bolts:
10mm one: 7.2ft lbs
12mm one: 16ft lbs
Rear bolts to rear upper arm or camber kit (all three):
43ft lbs
Rear nuts on end links:
top: 28ft lbs
bottom: 29ft lbs
Rear bolt that holds brackets and bushings on rear sway:
16ft lbs
Rear bolt that holds bottom of rear shock:
45ft lbs
Rear two shock tower nuts:
43ft lbs
when i insatlled springs on my car. i didnt bother...
__________________
Front end links:
29ft lbs
29ft lbs
32ft lbs
33ft lbs
33ft lbs
10mm one: 7.2ft lbs
12mm one: 16ft lbs
43ft lbs
top: 28ft lbs
bottom: 29ft lbs
16ft lbs
45ft lbs
43ft lbs
__________________
Originally Posted by silverdevil
German torque: goodentite
Thanks again rob sorry dont have money for manual yet so i must ask
and Dizzle i would appreciate help once i get the last pieces from UI
appreciate all the help you guys aka life savers
Tim1959
Jun 3, 2015 08:15 PM
cooldan1
Apr 23, 2015 10:49 AM
