Help on TSI Turbo Kit!!
Old Jun 10, 2004
2k2stylinchick's Avatar
2k2stylinchick is an unknown quantity at this point
I am in the process of getting my TSI Turbo Kit installed, but we ran into a couple of speedbumps. Any help would be appreciated.. I have the TSI Extreme Trubo kit for my 02 Civic EX, with the T28 Dual BB Turbo. Here are the issues, 1. The intercooler pipping runs right into my A/C, does that have to be removed or is there a way around it? 2. There has to be a hole drilled into my oil pan, the fitting I got for it (for the oil return) I was told, was for a steel oil pan, which I don't think that I have, am I wrong about this are there other fittings for that?
Thanks
Old Jun 10, 2004
dragoon's Avatar
the EX oilpan is magnesium/aluminum, so theyre right about that.
you may need to redo the piping to keep your a/c... and i never knew the TSI kit had a t28... the ones i saw were all t25's
Old Jun 10, 2004
I upgraded the turbo to a T28 Dual, We are trying to reroute the piping to go underneath the subframe... Question is the fitting that I got is for a steel oil pan will that be okay or do I need to change that too?
Old Jun 10, 2004
dragoon's Avatar
its definitely doable, but its considerably more difficult to weld one metal to a different one.
Old Jun 10, 2004
civicskater's Avatar
Chicks dig my scent
welding with aluminum is a pain in the ***, its extremely hard to make a bead...i suggest just finding an aluminum fittin(lowes or home depot has similar ones) and having someone weld it for you
Old Jun 10, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
The turbocharger is the reason why your a/c compressor wont bolt up after installing your downpipe. If you got the t25bb you'd be fine.
Old Jun 10, 2004
dragoon's Avatar
must be a tight fit
Old Jun 10, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
ask any welder.... you dont weld aluminum to steel or vise versa...since your oil pan is aluminum, get an aluminum fitting....
Old Jun 10, 2004
civic01vtec's Avatar
ask any welder, any real welder.....it don't matter if you weld aluminum or steel.........welding is welding
Old Jun 11, 2004
So let me quess, what you are saying is that if I didn't up grade the ball bearing, which gave me the T28 I would have been fine? Well that's stupid.
Old Jun 11, 2004
Okay does anyone have an idea where I could get another fitting then? I have already been to Lowe's and Advanced Auto Parts?
Old Jun 13, 2004
abmerop18's Avatar
Jam out with your clam out.
you gonna be at out next ohio meet with your turbo'd 7thgen? check the ohio forum
Old Jun 13, 2004
dragoon's Avatar
Old Jun 13, 2004
dragoon's Avatar
t28 = physically larger.
the t25 is available with a ball bearing as well.
HondaGuy7
Feb 22, 2016 01:00 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
beanhead
Sep 24, 2015 12:04 PM
