car shakes
Old May 31, 2004
detroittosag's Avatar
detroittosag has a little shameless behaviour in the past
car shakes
i recently took off my 17's to put the factory rims on for like 3 days.. then i put on the good rims again.. only now instead of them driving good like before, once i get above like 50 the front two tires starts to shake. i had them taken in for a balance, and they were perfectly balance.. should i get a front end alignment??? or maybe do i have to re-ajust the camber again???
Old May 31, 2004
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
do you have hubcentric rings? that might help. i had the same problem with a pair of steelies i got but i returned them for the reason that they vibrated.
Old May 31, 2004
tfnaaf's Avatar
BLDNPSI Mod
It's NOT the alignment. Wheel alignment cant cause vibration. Xenin idea sounds more likely. That or whom ever is doing your balacing dont know what they are doing. As for readjusting the alignment, it too wont change by taking your tires off, on, off, and on again.
Old May 31, 2004
well damn cause now i'm mad as hell that the car is doing what it does, and hasen't done that before i took them off... maybe is it the wheel bearings??? cause i remember in my other car ( a grand am). i used to have to change the wheel bearings all the time... and if so how hard of a job is it to do it myself?? i changed my other ones in my other car real fast.. but is this one different?? and how much are the parts.
Old May 31, 2004
flotsamm's Avatar
Swap the front wheels to the rear on the same side and test drive. If the vibration goes away or to the back of the car, its a balance issue. Sometimes it can be a bad tire that can cause a vibration and other things.
Old May 31, 2004
cool i'll do that right now
Old May 31, 2004
that did the trick.. but now whats going to happen when i need the tires rotated??
Old May 31, 2004
silverem2's Avatar
rotate front to back on each side and you should be fine, i had that problem and tried to rotate like this X instead of this | |.
Old May 31, 2004
tfnaaf's Avatar
BLDNPSI Mod
Take it back to whom did the last balance or if there is a warranty on the tires take them back and tell them to balance or replace
Old May 31, 2004
Zzyzx's Avatar
Autocross Junky
Just a question, but Do you have stock Rotors? because they may not be balanced.... and cause a bit of that vibration.
Old Jun 1, 2004
yea i got stock rotors... i ended up putting the back up to the front again.. and to anser one aquestion. i have directional tires, so i can only switch them to front and back.. not to the other side.
Old Jun 1, 2004
flotsamm's Avatar
You can rotate directional tires from side to side, but you'll have to get them unmounted and remounted on the wheels. Pain in the *** for sure. Now that you know that its one of the front wheels, either go get them re-balanced or try to figure out what wheel it is by swapping one side only. Then get that shiz fixed.
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
JDock
Nov 9, 2001 08:53 AM
colombianDXcivic
Nov 8, 2001 05:26 PM
AL
Oct 18, 2001 03:01 PM
mj1010
Aug 26, 2001 09:52 PM
