How do I reset the ecu?
Old May 22, 2004
streetglower's Avatar
How do I reset the ecu? Someone said unpluging the battery or unpluging the ecu harness. If so where do I unplugh the harness at? or are there other ways of doing this.
Old May 23, 2004
cim's Avatar
cim
cim is an unknown quantity at this point
You can reset using a diagnostic tool connected to the OBD connector, removing the ECM power fuse under the hood (no. 6) for at least a few seconds or by disconnecting the negative terminal of the battery for at least a few seconds.
Old May 23, 2004
skarteez's Avatar
skarteez is an unknown quantity at this point
disconnet neg battery terminal for like a minute or two.
reconnect
start car, idle for 15 minutes. DONT TOUCH THE GAS!!!!!!!!!!!
turn off car
turn on car, drive hard for a few minutes to get the ECU to relearn fuel curves, intake temps, air volume, etc...
then it should be adapted to the new things youve done (presuambly). this should also be done for every season so by the time the season is over, the car wont have to readjust to the new seasonal changes and stuff....
Old May 23, 2004
I thought it was the positive terminal?
Old May 23, 2004
No, negative. But just pull the fi-ecu fuse so you don't lose radio settings.
Old May 23, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Good idea, I never thought of that!
Old May 23, 2004
Mistro's Avatar
Mistro is an unknown quantity at this point
Yes what he said. ^ THe ecu fuse and not the battery. Although its easier to pull the battery cable its a pain in the *** to be ressetting your radio stations agiain and again.
Also there was a topic with different ways to "train" the ecu after resetting. It said that the best way was to hold the rpm at around 3k for 5 mins or so and that yeilded the best results but the 10 minute idle and drive of also works.
Old May 23, 2004
Yeah, it's still not known exactly how to make it relearn. Don't worry, though, it should adjust after driving through a tank of gas.
Old May 23, 2004
civicvtec1ps's Avatar
Search and Learn
Just take out ECU fuse.
Which is located under the hood.
Old May 24, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
take out ECU fuse
put key in ignition and turn to acc DO NOT START
turn off and remove key
pute ECU fuse back in.
Start car..
ECU is now re-set
Old Jul 12, 2004
antok86's Avatar
antok86 is an unknown quantity at this point
how bout not touching nething..and running car normal...for say a week or tank of gas...will it learn on its own????
Old Jul 13, 2004
That's right. You guys worry way too much about resetting the stupid computer. It will learn fuel curves as you drive. After a tank of gas, you should be set.
Old Jul 13, 2004
antok86's Avatar
oh ok thanks
Old Jul 13, 2004
tacheon's Avatar
tacheon is on a distinguished road
Here is the Honda ECM/PCM learn procedure.
ECM/PCM idle learn procedure.
• Make sure all electrical items are turned off.
• Start the engine. Hold the engine speed at
3,000 rpm with no load (in Park or Neutral) until
the radiator fan comes on.
• Let the engine idle for 5 minutes with the
throttle fully closed and with all electrical items
off.
NOTE: If the radiator fan comes on during this
step, the time it is operating must not be
included in the 5 minutes.
Old Jul 13, 2004
antok86's Avatar
CANT it learn on its OWN??? im scared to do THIs...im a newbie...
Old Jul 14, 2004
tacheon posted the procedure right from the service manual. Just do it that way, but it should learn on its own. It's very easy to do though. Just disconnect the battery first and reconnect it before performing the learn procedure.
Old Jul 14, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
I just started mine and let it idle for 15 minutes. It runs like a champ. Don't worry, the ECU learns as you drive. A few minutes on the freeway, and it will have adjusted itself.
I'm sure they don't baby every civic off the line to learn the idle. It'll do it regardless. The only thing that'll happen is that it may run rough when you first drive off before it had a chance to adjust.
Old Jul 14, 2004
antok86's Avatar
wat do you mean it will run RouGh?? u mean after u just installed the intake??
Old Jul 14, 2004
It doesn't matter. I just did mine to see if it helps my problem, and it didn't. There is no point in doing the idle learn.
Old Jul 14, 2004
antok86's Avatar
where can i get some sound clips of INake souNds?? hahaha...
Old Sep 15, 2004
JayFReaZy's Avatar
which exact fuse is this? more detail maybe? I need to get rid of my CEL.
Old Sep 15, 2004
davidoff1's Avatar
davidoff1 is an unknown quantity at this point
after resetting... wat if u dont let it idle for 15 mins and step on the gas wat will happen??
Old Sep 15, 2004
ojay's Avatar
ojay is on a distinguished road
^^ it won't learn right away, just do what tacheon said
Old Sep 15, 2004
The point is for the car to relearn idle rpms. You want to keep it at idle for 10 mins once the car is warm. Look in the manual for the fuse. It's called FI ECU.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
lowlife9
Oct 6, 2015 04:39 PM
senicalj4579
Oct 2, 2015 10:03 AM
Hutch1051
Sep 29, 2015 09:20 AM
ttamrekab
Sep 28, 2015 01:22 AM
