my car died..
Cocky guys kick ass!
my car died..
yup, died. i need help on what could be wrong. the lights got dim, the car kept cutting out, the transmission felt like it was slipping, wipers were delayed, radio kept cutting in and out.. tach, gas, other gauges just dropped.. i just had the alternator rebuilt, and tested.. so i duno. any ideas?
If this is while driving, it's the alternator and not the battery. Get it tested again. All the problems you're having are electronically controled. Hope you can get it working.
this happened after u got ur alternator rebuilt? hmm might be something wrong with it... get it tested again... cuz it sounds as if ur car is not charging properly and ur battery was drained because of that
EVERYTHING on your car is powered by electronics. That's why upgrading the tranny ground wire will improve response. Tranny shifting is controled by the ecu, which runs off power from the alternator.
Alternator is dead.... Same exact thing has happened to me, over the years I've had 5 alternators die (not in the Vic) and thats exactly what happened
any way it could be the speed sensor? i heard it can do some of those things. i don't get it, the guy rebuilt the alternator two times, and two people tested it on two different machines.. grr.
the speedometer/odometer have been dead already for a week, is that most likely the alternator too, or the speed sensor? the rest of the gauges kept working, until it all died lastnight.
Originally Posted by gearbox
That sounds like another problem. Alternator failing would cause all the gauges to act broken, not just one.
True!
usajags84
15
Aug 19, 2015 03:12 AM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
