Magnaflow exhaust hitting frame
Old May 16, 2004
sitinduk's Avatar
sitinduk is an unknown quantity at this point
Hi, I recently installed a Magnaflow catback on my 03 LX. Everything went smootly except that the piping that connects the muffler to the resonator hits the frame of the car when I turn. This piping bends to clear the rear control arm. It looks like it's bent too high, that's why it's hitting. Does any1 have a solution to this problem?
-Thanks
Old May 16, 2004
Crackhead79's Avatar
Funny, I have a '03 Ex and I have had no fitment problems, I've had the kit since Oct of 03. If yo wnat me to take a pic somewhere of something you might of missed just tell me. Good luck....
Old May 17, 2004
dragoon's Avatar
It shouldn't be, but try adjusting some of the hangers, pull on them or something.
Old May 17, 2004
blouisgod's Avatar
Life Begins > 6800rpms
You can move the hangers that go into the rubber mounts on the resonator to a lower point. By this i mean put the metal hanger into a lower point on the rubber mount. This will lower the pipe and help with the clearance. Of course, if you have your car dropped or lower it, this wont work. You may want to take it to a shop and have them fix it. Should be about 50 bucks.
Old May 17, 2004
sitinduk's Avatar
Thanks for your help guys. I'll try to adjust the exhaust again. I took some pictures of where the pipe is hitting, but they're pretty low quality. It only hits when I'm driving (turning). There is actually a little space when it just hangs there.
Webpage with pics
Old May 17, 2004
sitinduk's Avatar
By the way, I'm not lowered and have all stock suspension.
Crackhead79, if you could take a pic of your exhaust pipe that goes over the rear suspenstion and connects to the resonator, I would really appreciate it.
Old May 17, 2004
Not a problem give me minute, mine will look different though, because I'm dropped on the hayames and have a progress 22mm in the back-
Old May 17, 2004
Funny, I went to download the pics and the server did but then all my ride pics are gone-? WTF? oh, well here the are sitinduk one-by-one.
ID:	29566   Click image for larger version
ID:	29567   Click image for larger version
ID:	29568   Click image for larger version
Old May 17, 2004
sitinduk's Avatar
Crackhead79, your pipe definitely has more room to move than mine does. I noticed that you guys all have EX's. I wonder if the exhaust hangs differently on the LX or perhaps mine just happens to have a defective bend. I've emailed Magnaflow about this, but they haven't gotten back to me yet. I'll probably reinstall the stock exhaust so nothing gets broken in the mean time
Old Jun 9, 2004
sitinduk's Avatar
Update, I've reinstalled stock exhaust. Magnaflow finally got back to me. I had sent them these pics:
Here's what they had to say:
I showed the pics to my engineer and he said it looks pretty normal - the Hondas have tight clearances. He also said you should have between half an inch and 3/4 inch clearance right there where the tailpipe comes close to the frame. So if you have less than that, just loosen the system, re-align it and tighten back up after making sure you have proper clearances. Other than that, if you are still having problems, I would say just get some new rubber grommets from Honda. Hope this helps, thanks again.
I guess I'll try to reinstall the Magnaflow one more time. Maybe I just have to give it time to break-in.
Old Jun 9, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
I had some problems with my exhasut hitting also. Not a magnaflow, and in a different spot, but i fixed it by doing what the guy from magnaflow said. Loosen the pipes and you should be able to twist everything untill it fits perfect. Hope this helps, and be patient, because it takes a while to get it right.
Good luck.
Old Jun 9, 2004
PunkingCivic's Avatar
I need TP for my bunghole
you can alway use a hammer and beat a little more for the pipe.
Old Jun 9, 2004
HoldDaMayo's Avatar
HoldDaMayo is an unknown quantity at this point
How are you guys liking the sound of your Magnaflows?
Old Jun 9, 2004
blouisgod's Avatar
People love mine - I get compliments on it all the time. Its not to loud but definately noticible.
Old Jun 13, 2004
sitinduk's Avatar
Problem solved. I had left too much slack in the midpipe slip fittings. Although the piping from the muffler doesn't have any more clearance than it previously did, the exhaust doesn't rock as much as it used to. It no longer hits the frame when I turn. The whole exhuast feels like it's more solid. Happy, happy, joy, joy
mrwhos
Aug 11, 2015 02:03 AM
Kcpowerhouse
Aug 1, 2015 06:55 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Causemo
Jul 5, 2015 06:42 AM
